Red and blue dots on the screen its a 50 Zenith plasma tv
    New Friend:
    Problem Solver:
  • 9 Answers
Panel problem
Posted on Apr 21, 2013
  • david garcia Apr 21, 2013
    Panel problem???
Benimur
  • 6966 Answers
SOURCE: Zenith A25A11D No Red Color
Hi, If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem. Hope this works out for you and give you some ideas. Pls post again how things turn up, good luck and kind regards.
Posted on Aug 12, 2007
SOURCE: no sound or picture on my prima plasma tv
I HAVE A NICE PICTURE BUT NO SOUND
Posted on Oct 26, 2008
SOURCE: dlp samsung tv 50
This is a known defect that Samsung should correct at no cost to you whether or not your TV is under warranty. Contact Samsung at their 800-Samsung and tell them you have the 'white dot' problem - advise them that there is an alert on this issue. My TV is over 3 years old and they are taking care of it; just waiting for the part at the moment.
Posted on Dec 07, 2009
  • 66 Answers
SOURCE: Zenith 50'' TV blurry
There is internal elignment with the guns on the projection unit. They come loose. TV guy time
Posted on Mar 30, 2010
  • 66 Answers
SOURCE: 50 inch sony tv has
this is usually a good indicator that the tube is getting ready to kick up the daises. but not always it may be a problem with the adjustments on the motherboard where the tube connects tayo it and it may need to be adjusted.Good luck.Hope this little bit of info helps!!!!!
Posted on Jan 03, 2011
MODEL TV #Z50PX2D red dots on sceen and fuzzy picture in corner from time to time
the tv has a bad panel you can go to the web site put in your model number and look for a firm ware update but it may not fix it i have been working on tvs a long time all the ones i have seen needed a new panel/screen witch cost to much to fix
Oct 06, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
After warm-up screen flashes and loses color but comes back on and off intermittidly. This is a 50" Zenith Plasma tv. thanks.
Sounds as if a cable connection is bad. Check the cables first. If cable are good, change inputs, if cables are bad replace cables. If it's component, make sure that red, blue or green didn't come loose on both sides...the tv and the source. If you still have problems, check for red video noise on the screen itself, preferably when it's on but with on input (black) If you notice this, your plasma is failing.
Mar 23, 2011 | Zenith Z50P3 50 in. Plasma TV
HP-R5072 50 in. HDTV Plasma Television: i have one red dot on plasma screen. it is always ...
Unless you see more red dots, this kind of "defect" is under specifications for this size of PDP, if you do not like it, the PDP module must be changed
May 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Red Dots
This is know as diffusion. You will need to locate the Vs adjustment inside the TV and vary it up and down by NO MORE THAN 10 volts. If this does not correct the problem then you will need to replace the Plasma panel.
Aug 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
Please help us solve the red line through our 50" Zenith plasma
write an experience that you went trough where you had to use to help you solve this.
Apr 21, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Blue dots on my lcdtv
Sometimes the voltage can be set to high by the factory. Throughout time, blue dots will appear. You will have to remove the back cover off the tv, find the "voltage Screws (they are labeled) and turn down (left) JUST A Notch. Have seen this done many times.
Pray that the panel isn't blown out or bad projector tubes. They are expensive.
Blue dots and screen flicker are VERY common on the newer LCD and Plasmas
Also, if you have a pixel setting on your TV (not sure if that one has it) Try setting it to
480p.
Jan 17, 2009 | Hitachi 50HDX60 50 in. Plasma Television
Dell W3000 display issue - band of red dots on the left side
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
Junk TV & Poor service
zenith agreed today to replace mine.
Mar 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith 50 plasma
plasma parts are currently alot on backorder, so it will take time to get them.is your repairguy ASC for LGE?? if not, take your TV to an ASC. they get the training and know what they are doing,not those wannabe repairman........
Jan 10, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
