Question about Yamaha RX-V995 Receiver
Remote stoped working
It started not working just from time to time now its not working at all, i am thinking maybe its in the receiver?
Mine did this also. Its been years since i fixed it but the problem was caused by a ribbon cable located in the front by the volume control. I took the cover off, reseated the cable and it has worked fine since.
Posted on Aug 19, 2009
The four button remote with keyless entry and remote start on my 2001 buick lesabre has stoped working. The keyless and trunk and horn functions all still work fine just the remote start has quit working. ...
it maybe that the relay in the alarm module for the starting function has stopped working. your best bet would be an alarm shop where they can test the connection for function. have seen this issue several times. Does the engine turn over at all? if it does then the time for cranking may need to be adjusted.
Jan 11, 2014 | Buick Cars & Trucks
Need to fix my car sterio system
Start by checking your grou;nd if that does not work take your positive wire and your remote wire on your amplifier make you jumper wire in touch both the positive an remote only in and see if it comes on if it does not then you need to go further and maybe replace amp 6_28_2013_8_57_31_am.jpg
Jun 19, 2013 | Audio Players & Recorders
My Hunter Fan stoped working. The light works but the fan does not work on any speeds. I hear the fan click when I press the different speeds on the controller. My grandaughter was here and kept taking...
If you hear any humming from the fan when you're trying to turn it on, then your motor is froze. I'm thinking from your description of being able to hear the actual fan switching but getting no results, it's probably the motor.
Aug 28, 2017 | Hunter Ceiling Fan Remote Receiver...
The remote has stoped working?
Remote testers are available (5 dollars) or you can take to Radio Shack to determine if problem is remote or set.
all sets have a remote receiver usually on front that receives the infrared signals from the remote===either the remote control or the receiver is bad.
Mar 11, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
MY DODGE RAM HAS A FACTORY INSTALLED REMOTE START BUT THE REMOTE STOPED WORKING I CHANGED THE BATTERY BUT STILL DOES NOT WORK ANY DEAS WHY
Oreilly Automotive stores have a little device the picks up a signal from a remote. Maybe your local parts store will have one. This will verify that your key F.O.B. is working. After that....fuses or possibly a frequency switch in the key FOB got bumped when you changed batteries. Otherwise, catastrophic failure....sorry.
May 09, 2010 | 2007 Dodge Ram 2500 Mega Cab Laramie
Might be a fuse but im not sure which one
Check the diagram behind the fuse panel...if you cant find one go to vwvortex.com
Jul 07, 2009 | 2000 Volkswagen Beetle
Cannot get it on video channel
sanyo are bad for not letting you get to the "game" channel as they call it. If there is nothing wrong with your remote there should be a button labled as "GAME" push that one. If the button has stoped working like mine did one time then there is not other way to get to the video channel you will have to order another remote from the manuf. they run about 50.00 I think they do that on purpose just to get more money out of people, mine stoped one time and there is abosolute no way "or at least on my model" to get it into game mode . they said that I had to order another remote, well I refused because of the price of it , I wanted another tv for another room and luckly for me the new remote that came with the new tv works the other tv so I was able to turn it to game mode.Good Luck
May 24, 2009 | Televison & Video
Tv does nit respond to remote
The problem is inside the TV, caused by a cold soldering on the circuit board where the infrared receiver cables are connected. Needs to be resoldered.
Dec 16, 2007 | Zenith E44W46LCD 44" Rear Projection...
Yamaha RX-V995 Receiver Logo
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
