Question about Jenn-Air JED8430 Electric Cooktop
30 plus year old jenn air cook top
Need to replace my cooktop with newer model. One that is less noisy and with up to date features. Do you have replacement parts for model 2375/90ERS?
  • 10865 Answers
SOURCE: I have an old Jenn-Air cook top with down draft,
Hello. Work directly with Jenn Air on this. Go to this link which includes a toll free number and a link to IM with their technician, for free.
http://www.jennair.com/flash.cmd?/#/page/customerservice/
Posted on May 05, 2010
SOURCE: cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Posted on Jun 18, 2008
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
blueextc3221
  • 15935 Answers
SOURCE: Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Posted on Apr 29, 2009
localwonder
  • 6784 Answers
SOURCE: all cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Posted on Nov 04, 2009
I have a older Jenn air electric cook top and I need to replace the burner element on one side. How do I get the old one out and where do I find parts. JEA 800 ADB
get a gas repairer to check for you or you go back to where u bought it and the burners will be replaced or sold to you if the cooktop is still under one year warranty
Jan 19, 2011 | Jenn-Air JED8230 Electric Cooktop
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
CLICK HERE
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
11 year old jenn air expressions cook top
gud day,for my sujjestion is replace the unit coz if u get the part is more expensive to new one.unless is we have a rewind the motor like in the phillipines thats more cheaper to the new one,11 years is enougth for ur usage, that my sujjestion
Jan 10, 2009 | Jenn-Air Expressions AC110 Electric...
Melted plastic help!!!!!!!
While the cook top is cool, use a razor blade scraper to remove most of the melted plastic.  Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop,  and then wipe off the excess.
Sep 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Coils don't heat
The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
Jenn-Air JED8430 Electric Cooktop Logo
735 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
