Question about Hayward Industrial Products Hayward Star-Clear Cartridge Filter Series & Separation Tank Tie Rod C
Check valve in c1100 star clear filter broken
My 2004 roadstar 1700 is not running right it seems to be missing and not have the power
Hi, Paul and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Fuel filter clogged.
14. Old or contaminated fuel.
15. Fuel tank vent system plugged or carb vent line closed off.
16. Gas cap diaphragm valve faulty.
17. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
18. Carburetor controls misadjusted.
19. Incorrect valve timing.
20. Valve springs floating, weak, or broken.
21. Damaged intake or exhaust valve.
22. Incompatible performance parts.
23. The control module may be in "LIMP" mode.
24. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Engine Cut Out and the Infamous CPS problem
Re Rear Cylinder misfires Road Star Forum Yamaha Road Star
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Feb 15, 2017 | 2004 Yamaha Road Star
Spuddering 2006 Yamaha V Star Classic
Hi, Anonymous and the usual suspects are:
4. Spark plug cables in bad condition and leaking.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha 650 star sputtering high speeds
http://www.starbikeforums.com/forums/49-v-star/9084-v-star-acting-very-sluggish-sputtering.html
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jul 03, 2014 | 2004 Yamaha V Star Classic
Pump works fine and the fuel filter is clear lots of fuel through the pet **** . where to go from there as I thought I cleaned all the carb jets out well.
9. Intake air leak.
Need carb help Star 1100 Yamaha Star Forum
01 Yamaha star 650 loss of power and backfiring Fixxit
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jun 23, 2014 | Yamaha V Star 1100 Classic Motorcycles
CYLINDER SOUNDS LIKE CUTTING IN ONCE AND A WHILE MAKING POWER CUT IN AND OUT ON A 2000 YAMAMA 650 V STAR CLASSIC HAVE ALREADY CLEANED CARBS
11. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Old dead or bad fuel.
13. Fuel tank vent system plugged or carburetor vent line closed off.
14. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
15. Carburetor controls misadjusted.
16. Damaged carburetor.
17. Incorrect valve timing.
18. Weak or broken valve springs.
19. Damaged intake or exhaust valve.
20. Check for engine trouble codes
New VStar 1100 Owner Shuts down while riding
Re HELP Star 650 dies at half throttle Road Star Forum Yamaha Road Star
http://s.productreview.com.au/products/manuals/32141_563ae9ef16ab5.pdf
http://www.starmotorcycles.com/assets/service/manuals/2003/lit-11626-16-05_22.pdf
Oct 31, 2013 | Yamaha V Star Classic 650 Motorcycles
Yamaha 1100 v-star bogs down when throttle opens
9. Intake air leak.
Yamaha Star 1100 Throttle problems
http://www.starbikeforums.com/forums/49-v-star/7338-v-star-1100-bogs-past-quarter-throttle.html
Sep 01, 2013 | 2001 Yamaha V Star 1100 Classic
99 yamaha vstar 650 clasic no power when acelerating i cleaned carb
9. Intake air leak.
Losing power on Vstar 650
Jul 15, 2012 | 1999 Yamaha V Star Classic
I have a yamaha 650 v-star changed jets and needle valve and cracks and pops around 50 to 60 mph
Hi, Bikerclev and the usual suspects are:
9. Intake air leak.
2004 Vstar idle only on full choke problem
Jun 01, 2012 | 2005 Yamaha V Star Classic
Yamaha Road Star Silverado 1700 loss of power in fourth and fifth gear
13. Multiple carburetors out of sync.
14. Fuel filter clogged.
15. Old or contaminated fuel.
16. Fuel tank vent system plugged or carb vent line closed off.
17. Gas cap diaphragm valve faulty.
18. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
19. Carburetor controls misadjusted.
20. Incorrect valve timing.
21. Valve springs floating, weak, or broken.
22. Damaged intake or exhaust valve.
23. Incompatible performance parts.
24. Control module may be in "LIMP" mode
25. Check for engine trouble codes.
Re No top end power Road Star Forum Yamaha Road Star
5th Gear Slipping
Yamaha XV1700P Service Manual
May 14, 2012 | Yamaha Road Star Silverado 1700...
Have a Yamaha 1300 v star spitting and sputtering why?
Hi, Handyman1167 and the usual suspects are:
Motorcycle Message Board Motorcycle USA
Yamaha XVS1300A 2007 Service Manual
YAMAHA XVS1300A Owner Manual
Mar 22, 2012 | 2007 Yamaha V Star 1300
SPUTTERING ON A 2006 YAMAHA V STAR CLASSIC
Hi, Amendina280 and the usual suspects are:
9. Intake air leak.
Sep 25, 2010 | 2006 Yamaha V Star Classic
Hayward Industrial Products Hayward Star-Clear Cartridge Filter Series & Separation Tank Tie Rod C Logo
226 people viewed this question
Top Hayward Industrial Products Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Hayward Industrial Products Water Dispensing and Filtration Expert? Answer questions, earn points and help others
