Question about Whirlpool Refrigerators
Whirlpool MODEL ED5VHGXML13 freezer not cold enough
Frost on bottom of evaporator coil and the rest of the coil is clean
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
eagle338
  • 4889 Answers
SOURCE: frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Posted on Sep 02, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
  • 103 Answers
SOURCE: the motor on the Kenmore refrigerator is running continuously. How do I stop it? I just cleaned out the dust from the coils underneath and replaced the kick-plate at the bottom
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
Posted on May 31, 2009
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
I have a daewoofrg1820brb I've had it plugged in 4 2 hrs now freezer is cold but the bottom isn't getting cold
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor. Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | Refrigerators
Sounds like it's working but not getting cold enough in freezer or refrigderator
In my experience, the biggest culprit causing these symptoms is the defrost heater. This is a heating device that melts frost off the "evaporator coils" better known as the coils usually located inside the freezer area of the unit. These coils get very cold and warm air that is let inside when any door is open, will carry moisture with it that will accumulate like water on the outside of a cold glass in summer time, only it accumulates on the evaporator coils and turns to frost.
As your fridge cycles through its operating stages, one part of the cycle turns off the cooling and turns on a heating device of varying types to melt the frost and ice off of the evaporator coils so it can drip down and flow through a small hose through an opening in the bottom of the fridge and into a pan underneath the fridge where it evaporates back into the air again.
If the heating device never comes on, or becomes inoperative, the frost will slowly continue to collect on the evaporator coils until it becomes a solid block of ice. This now greatly reduces the ability of the evaporator fan to blow the cold air around the coils throughout the freezer and the rest of the fridge. The ice built up around the evaporator coils will still provide some cold, but will significantly prevent the fridge from operating properly.
Another cause may be the evaporator fan not operating correctly. If it doesn't blow air over the evaporator coils well enough, cold air will not get distributed through out the fridge. Cold air tends to "fall", so the bottom of the freezer will be the coldest. Generally, there is an adjustable hole in "side by side" units so that the amount of air coming through that hole can make the "meat crisper" colder. In fridges where the freezer is on the top, I've seen the evaporator coils (which often incorporate "fins" like those on a car radiator, turn into a solid block of ice.
25823064-nzcmabjorfygbev20le00e4d-4-1.jpg Also check for dust collecting on the condenser coils on the outside of the fridge. These dissipate heat drawn from inside the fridge and take it outside the fridge. These are often located on the back of the fridge or underneath the fridge. Dust and fluff act as insulation and degrade their ability to work properly.
Obviously, to repair the fridge, you should relocate the contents of your unit until you can repair the fridge. Fixing your fridge will take at least a few hours even if you can get your hands on repair parts quickly. This will involve unplugging the unit and locating the items I've referred to. Either allow the accumulated ice to melt naturally or GENTLY speed up the process with a hair dryer or heat gun. Do not use any force removing the accumulated ice and frost, you could easily damage the coils and make things much worse than they already are. Even to the point of making the unit uneconomical to repair.
Without your posting a make, model, type of freezer/fridge arrangement or other details, it is difficult to assist you further. Part placement and component locations vary greatly in this appliance.
Aug 15, 2015 | Refrigerators
Does the control thermastat have anything to do with the freezer on my refrigerator getting cold but not freezing
If you remove the evaporator cover and look at the frost on the evaporator is it fairly even frost from top to bottom? If you don't have frost on the bottom half of your evaporator then you have a freon leak. Do you have a model number for your unit?
Mar 15, 2013 | Whirlpool Refrigerators
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 21, 2011 | Whirlpool GT1SHTXM Top Freezer...
Whirlpool Refrigerator model EHT-201VK is leaking water inside and outside.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Sep 28, 2010 | Whirlpool Refrigerators
It quit making ice and there is frost on the back of the freezer
If this is a auto defrosting freezer then you defrost clock or defrost heating element may have failed. It is not making ice because the evaporator coil is frosted up therefore not cooling freezer cold enough to cycle the icemaker. You can manually defrost by removing everything and unplugging and leaving doors open for a day or two. Or you can look at having it repaired if you are very mechanically inclined you can try to repair yourself.
If I can help with anything else please let me know.
Apr 15, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
Freezer & fridge not cold enough, frost in freezer
Refrigerator or freezer is not cold enough
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 31, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
I HAVE A FRIGIDAIRE REFRIGERATOR WITH BUILT IN ICE MAKER MODEL # FRT18INLHW APPROX 7 YRS OLD. THE REFRIGERATOR AND FREEZER ARE NOT GETTING COLD ENOUGH. I CLEANED THE COMPRESSOR AND CONDENSER COILS. IS THE...
if needs sealed system repair problaby cheaper to buy new. try removing the back wall of freezer section, is there excessive frost build up??? is the fan behind tere even running(if not replace hte fan). if theres frost built up hten look for a defrost problem. Perhaps a defrost timer, defrost thermostat, or even a bad heater assy. if you remove to coil adn find a ball of frost in 1 corner nad rest of evaporator is clean and dry, thats an indicator of sealed system problem
Mar 22, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
