Question about Roper Dryers
Need wiring schmatic for roper dryer model res7745pq0
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Posted on Oct 06, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Our Roper RES7745PQ0 is taking
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 05, 2010
heatman101
  • 43501 Answers
SOURCE: My electic dryer..Roper RES7745PQ0 wont
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 21, 2011
oldTech2332
  • 2341 Answers
SOURCE: i have a roper dryer model # res7745pq0 doesnt
What you need to check are the two thermostats mounted to the heater housing BOTH should have continuity
Posted on Aug 11, 2011
Dryer too hot
dryer has a safety a high limit switch in back of dryer at heater element should be only 2 wires small round size of a nickel turn power off first
Jun 20, 2012 | Roper Dryers
My electic dryer..Roper RES7745PQ0 wont start.. I hear the timer clicking... what's wrong?
heatman101
Mar 21, 2011 | Dryers
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Jan 19, 2011 | Roper Dryers
Admiral dryer timer schmatics
You will need to provide the Model #. You can try this link and they may have the wiring diagram available. Just enter in the model number and see if the diagram comes-up as part of the breakdowns. Good Luck. http://www.reliableparts.com/models/
Sep 24, 2010 | Dryers
Orange wire
look in the wire schematics that came with the dryer or look them up online. They should tell you what that wire is for.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
I have a Roper dryer and it just turns off we can
first thing to do is to find out whats wrong with the cord, get to the part of the cord that goes into the machine, wires are loose. a 220volt dryer will not heat if one of the wires are loose. you need to get into machine and make sure wires are tight. this is also a safety hazzard, do not leave machine plugged in until problem is solved
Sep 02, 2009 | Roper REX4634KQ Electric Dryer
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryers Logo
47 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
