Question about Dryers
GE DHDSR46GE1WW dryer squeaking
Horrific squeaking noise while running
Illeagle
  • 525 Answers
SOURCE: GE Dryer makes an intermittent noise when drum is turning with clothes
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
SOURCE: how to stop squeaking noise on dryer
The roller bushings/bearings and the motor need lubricating.
If you want help with how to do this, let me know.
Posted on Apr 30, 2009
  • 4088 Answers
SOURCE: GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Posted on Aug 28, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My GE Dryer Model # dx4500ee1ww makes a load
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on Aug 11, 2010
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
How do I take the cabinet off a GE gas dryer model # DHDSR46GE1WW to check inside?
The following website may be helpful:
https://www.partselect.ca/Models/DHDSR46GE1WW/Instructions/?InstructionID=21302
This was extracted from the website:
Remove the two screws at the front above the drum opening (with the dryer door open). The top panel then lifts off. I removed the screw at each side that holds the front panel to the side panels, tilted the front panel forward, which disengages the front of the drum from the front drum glide bearing. I then lifted the front panel slightly, unhooking the bottom of the panel from the dryer base, and swung the front panel aside.
Oct 10, 2017 | Dryers
Dryer squeaks when running with clothes in but not when empty
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 30, 2011 | GE DBXR463EDWW Electric Dryer
Our front loading GE dryer is making a high pitch squeaking noise while operating...
heatman101
Dec 16, 2010 | GE DBVH512EFWW Dryer
My GE dryer goes squeak-squeak-squeak when it is turned on
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | GE Dryers
Ge driver 10 years old dryer squeaks and if i manually spin drum squeaks what should i do
heatman101
Nov 07, 2010 | GE DRSR483ED Electric Dryer
My dryer squeaks when running a load. How do I fix it?
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 11, 2010 | GE DPSB613EDWW Electric Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
Feb 19, 2009 | Frigidaire Electric Dryer
Clicking noise
heatman101
vbmvc
Jan 29, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryers Logo
78 people viewed this question
Top Dryers Experts
