Question about Broan-NuTone Dryers
Nutone model 665rp motor for heater fan is too loud how can i fix this?
This is a brand new unit. the fan for exhaust is not loud but heater fan is way too loud!
4 Suggested Answers
SOURCE: Nutone 665RP fan/light/heater all not working
Hunt for a tripped GFCI and push reset. The ground fault protected receptacle may be in a nearby bedroom, hall, or basement.
Posted on Jan 18, 2010
Testimonial: "THANKS! I brought an electrician in after I smeleled burning and there was bad arcing going on. He rewired it properly and everything is good now. T"
karns
  • 122 Answers
SOURCE: we have a "Nutone"- ceiling
You might be able. check Ebay. but it being as old as it is, you may not be able to find parts anymore.
Posted on Aug 13, 2010
SOURCE: NUTONE HEATER PROBLEM
contact nutone. the problem is that the sensor that shuts off the unit to prevent overheating is too sensitive or faulty. nutone website seems geared towards selling their product so you may have to call them direct at 1-888-336-6157. this is customer support. good luck.6-6157
Posted on Nov 28, 2010
My NuTone Model LS-100SE motor is going bad and I can't find a replacement anywhere, can you help me or at least tell me a good replacement fan that would fit in the same fan foot print?
This is a hassle. I have had to replace several of these and it seems they come up with a new motor/model every few days. Seriously, call them and ask if there is a replacement motor for that unit. There may be. They may also give you a recommended replacement. this is usually a different size by a bit. You just have to trim some of the sheetrock to get it to fit. unless you can only find one that is smaller. I use caulk around the edges to get a good seal and cover up. You can also try cleaning the "fan" part of the unit. this often gets dusty and becomes off balance. A good cleaning and one or two -small- drops of oil may buy you some time.
May 06, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
Feb 23, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
What is the thermal fuse temp in a Nutone 665rp heater?
Our thermal fuse blew as well, and my son was able to read the small print. Mine is a MicroTemp SRCAXK G4A01 TF 100, which according to the ThermoDisc website appears to have an open temperature of 100C (212F).
Dec 11, 2010 | Broan-NuTone 665RP Electric Compact Heater
Mar 03, 2010 | Broan-NuTone N-668RP Combination Light Fan...
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Dec 06, 2009 | Broan-NuTone N-668RP Combination Light Fan...
Should I buy a new exhaust fan or try to fix old one?
If the air flow in the duct is restricted, that can cause excess noise also.
Jan 25, 2007 | Broan-NuTone N-QT9093WH Combination Heater...
Noisy fan
We had our house built with the same Nutone fan/light units in all 4 bathrooms. Moved in in 2002. One of the units starting making a loud noise last month. I popped the plasic cover off the light, then carefully pulled out the bulb, then unscrewed the wingnut in the middle. That allowed removal of the light assembly. Then I had access to the blade and motor. I found a lot of dust had collected on the motor and blade. I blew most of it off with compressed air (like what you would use on a computer), then used an electronic cleaner on the motor, then wiped off the blade and motor with a clean cloth.
I then crossed my fingers and turned on the fan.... It worked! It was quiet again. I waited a week before posting this. The fan is used every day. It is still quiet today.
If it ever needs replacing, I saw that Nutone sells the motor alone for about $22, that's a lot better than replacing the whole unit for around $70.
Mr. J.
Nov 17, 2006 | Broan-NuTone N-769RF Combination Light Fan...
Dryers Logo
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
