Question about Dell Computers & Internet
Ethernet port not detected/no drivers
I want to use my onboard ethernet port to connect to the internet and my computer doesn't detect it.
  • Chinmay patil
    Chinmay patil May 11, 2010
    what is your system model ?
  • 66 Answers
Download the network driver
Posted on Mar 12, 2009
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Speedstream 6520 driver
Windows doesn't detect Ethernet connected devices. You could hook up a dozen Ethernet Modems and Windows would not see any of them, but they all would work fine using TCP/IP. It is not like you installed the DSL Modem/Router inside the case of the PC. You do know how Ethernet works, right? The only driver needed is the correct one for your Ethernet card, but that comes the Ethernet Card or the Motherboard Drivers CD for onboard Ethernet.
Found a few things, here are some websites to try:
Troubleshooting: Here
USB Driver for your Speedstream: Here
Sep 25, 2009 | Computers & Internet
Reinstalled windows xp now it says no modem detected
probably need your ethernet card reinstalled on your pc. right click on my computer and goto properties, then click hardware and device manager- you will probably have a yellow ! or ? by "ethernet controller"
you will need to goto the manufacturer of your computers website to download the driver on a diff computer and install it on yours.
Jun 03, 2009 | Computers & Internet
I'M TRYING TO RELOAD CABLE PROVIDER INTERNET SOFTWARE AND DRIVERS
Locate the chipset for Ethernet Card whether it is DLink or Relatek 8139xx series., or if any onboard chipset series, then trace for the drivers, for it, for Onboard you have Motherboard Cd, and can easily avlble on the net...
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
I unistalled the ethernet driver from my sons computer
If the ethernet port is on the motherboard (if it is near the keyboard and mouse plugin) you should find the make and model of the motherboard, go to the manufacturer's website on another computer and look for "Driver Downloads".
If the ethernet port is on a card that plugs into your motherboard (if it is down towards the bottom of the computer in a slot area) you should find out the manufacturer and model number of the card and proceed to their website from another computer.
Once you've downloaded the appropriate driver, you can use your flash drive to transfer it over to the computer in need.
Mar 25, 2009 | Computers & Internet
Ethernet port on laptop does not detect wire
That message always comes up if you have the driver loaded for the ethernet port but no cable connected to it. If you are not actually using the port, don't worry about it. Everything is fine.
Mar 04, 2009 | HP Pavilion dv6000z Notebook
Cannot detect device
Connect the phone while the computer is off. Power on teh computer and it should detect a new USB hardware device. You should then see two new drive designations. 1 for the phone's memory and teh 2nd for the onboard memory card if you have one installed. Remember for the first connection the computer must be off when you connect the phone.
Jan 20, 2009 | Apple iPhone Smartphone
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
Ethernet port
Try reloading the ethernet drivers from the device manager. Uninstall the drivers then reboot. It will find the hardware and reinstall the drivers. Then update the drivers from HP's support site. If you still have the issues, then it may be a faulty port. Take it in and have it checked out.
Jun 30, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
420 people viewed this question
Alun Cox
