Question about Electrolux AWF1235 Front Load Washer
Whats is the total weight of electrolux ewf 1495?
Product is electrolux washing machine front load model ewf 1495the problem is i need to know the gross weight of the unit.
    President:
  • Electrolux Master
  • 2,651 Answers
Thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Posted on Mar 12, 2009
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Electrolux EWF 1495, Starts but dosent wash. Drum turns about twice then stops for a couple of minutes, turns then stops. It then indicates cycle ended but didnt rinse, spin or drain or spin. These can be...
OK, first remove the rear access panel. You will see a drain boot going from the tub to the pump. You will need to remove that boot and inside is a filter that you need to clean out. Reassemble and run a load and let me know what happens.
Dec 02, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
May 27, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
Electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Feb 16, 2008 | Electrolux EW1000i Front Load Washer
Electrolux AWF1235 Front Load Washer Logo
419 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
