Question about Alba Televison & Video
Alba dvd-273 the linking cable for the 2 screens which has the DC, IR link and AV cables has a break in
  • 4 Answers
SOURCE: INeed av cable for Trutech 7? Dual-Screen Portable DVD Player
Okay, I just had to replace both the DC power and a/v cable for this Trutech DVD player and here is the solution. The a/v cable is a 4 pole 3.5mm cable, which I found here: http://www.techcables.com/6-ft-3-5mm-4-pole-mini-av-to-mini-av-camcorder-a-v-cable-p-36.html I went to Radio Shack and bought the coax style DC power plug ends which were size B and soldered new ends onto the old power cable, tip to tip, sleeve to sleeve: http://www.radioshack.com/product/index.jsp?productId=2102598
Posted on Dec 14, 2009
  • 308 Answers
SOURCE: Where can I buy AV cables for this
any electronics store
Posted on Apr 21, 2010
SOURCE: Need another set of tv-to-tv cables. An a/v cable and a dc cable
I had to move my AV cable around quite a bit to get the second monitor to come on. I realized it was the cable and not the connection by holding steady the connections and moving just the wire. I checked Radio Shack and Best Buy - no luck...
Then I did the following (takes 30 minutes max):
1.) found the portion of the cable that was bad
2.) carefully sliced open the outer jacket (with a box cutter razor),
3.) carefully pulled the wires (white, red, yellow, and bare copper ground) out of the outer black jacket. Inspected and found no visible defects. Realized that likely the yellow wire (probably the video feed) was shorting against the bare ground...so did the following remaining steps to remove the ground away from other wires.
4.) cut and unwound the ground,
5.) put the white, red, and yelllow wires back inside the outer black jacket, but left the bare ground out
6.) wrapped the two ends of the bare ground (that I cut in step 4) around the outer black jacket (still containing the other wires)
7.) reconnected the two ends of the bare ground, by twisting them together (you'll use-up an inch or two of the ground to re-twist it, so you will have to leave a small bump in the cable from the excess black jacketed portion.
8.) use black electrical tape to wrap all the wires together from the portion we opened-up.
Works like a champ.
Posted on Jul 12, 2010
SOURCE: I've been using AV cables
Configure the player to output Y/Pb/Pr to the TV. Make sure it's not configured to S-Video or anything else.
Posted on Nov 08, 2010
SOURCE: AV Out cable for portable Zenith (DVP-615) dvd.
I lost the AV cord to my Zenith DVP-615 portable DVD player too. I bought a standard RCA AV but it did not work. I found my cord so I was able to compare.
The standard RCA AV cable has a 4-part mini-plug. The tip is white, next is yellow, next is ground and the base is red. For the Zenith DVP-615, the tip is yellow, next is white, next is red and the base is ground.I never found where to purchase a replacement but perhaps this will help someone make their own.
Posted on Jan 14, 2012
Why has my Alba TV Screen say no Sygnal
how is youre cable connected to the 1-tv 2-cd/dvd player 3-amplifier, coming from satelitte..If you watch a dvd, somtimes you half to push the tv.video button on the dvd remote control just once to allow the tv cable signal to pass to the tv. each time you watch a dvd it blocks the tv signal. this is normally true unless you have a special wiring configuration
Aug 30, 2014 | Albatron Computers & Internet
I am trying to Connect my TV no: ALT2260M to Geepas DVD but not connected how can i start functioning?
Check its connecting wire [AV cord] first for any internal breakage to its conductor strands. Try with a new AV cable. After connecting the cable with TV and DVD player, switch the input to TV to AV. Power On the DVD player. If all connections are OK, you should see the brand emblem display of the DVD on TV screen. If not, make sure that there is some fault, either with TV or DVD player. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 04, 2014 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
We have an Alba DVD-273 in car dvd players (twin screen) however the 3 point double ended wire is broken. We need a new one but cant seem to find them anywhere?!
I haven't solved it yet, same issue, I patched together a broken power plug on mine, but the guys at Maplin sell all the plugs (they say) and you can solder your own together., mine's broken again,so I'll try that soon. Unless you came up with a better solution in the meantime?
Mar 21, 2010 | Alba Televison & Video
Jun 16, 2009 | Televison & Video
Trying to set-up dvd
If non HD, just link a scart cable from rear of TV to rear of DVD, if HD use a HDMI cable , there will be a number next to the socket on the TV that you plug the cable in, select that number using the remote and away you go. (If dvd recorder, av 2 usualy sends a signal to the DVR for recording)
Could tell you more precise if you posted the make & model of units.
May 28, 2009 | Televison & Video
Alba DVD recorder won't recognise any discs
The Alba DVD recorder may not recognise any disc due to one or two of the following reason.
1, the optical pick up (lence) may be dirty or may have gone bad.
2, the cable which connects the optical pick up to the circult panel board may have go borken.
Jan 04, 2009 | Televison & Video
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
37 people viewed this question
Top Alba Televison & Video Experts
Demonic-2011
Demonic-2011
Michael Galve
Michael Galve
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
