Question about SkyGolf SkyCaddie Handheld GPS Unit
Skycaddie sg5 screen dim
Screen is dim
4 Suggested Answers
  • 39 Answers
SOURCE: How do you reset the username and password on a Skycaddie SG5?
What are you trying to login into lol the title just says " How do you reset the username and password on a.."
Im going to guess a computer? boot into safe mode (press f7 on start up) and then log in to the admin user account (no pass) from their u have access to pc from their run CMD by going start then run then type cmd and hit ok once that opens create an admin acount by doing this
net user /add useraccountname mypassword
net localgroup administrators useraccountname /add
net share concfg*C:\/grant:useraccountname,full
net user useraccountname *
ofcourse replace useraccountname with waht ever username you want and the same with password hope this helped
Posted on Feb 18, 2009
SOURCE: registration
Where do I find Caddiesync>
Posted on Dec 24, 2010
SOURCE: My Skycaddie SG5 will not
I have put a new battery in but still no luck
Posted on Jun 23, 2011
New battery and still not holding charge
Not sure what kind of battery you are using in your GPS. If you can put in AA or AAA size batteries, try to use NiMH rechargeable batteries the can be bought with capacities till 2500 mA/h. (sometimes suggested 2700 on the battery) but still 2500 mA/h is very much. Do charge the batteries with a charger that is capable to charge correct. When putting a NiMH battery on an old charger for NiCd batteries, the battery never get the full capacity.
If the Battery is inside and you must go to a repair shop for replacement, please ask if they can check if the GPS is not draining to much power, because of any malfunction.
Oct 28, 2013 | SkyGolf GPS
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Registration
May 28, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I install caddieSync?
cannot log on to skycaddiesync for my new skycaddie.
Jul 30, 2009 | SkyCaddie SG2.5 GPS Receiver
Feb 17, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
SkyGolf SkyCaddie Handheld GPS Unit Logo
47 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
