Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
My dishwasher shuts itself off
My frigidaire dishwasher will let me select a cycle, then it will run for 3 minutes. It then shuts itself off and all the lights start blinking on it. I can get it to run through the full rinse cycle but that is it. Any other cycle will run for 3 minutes like it is filling with water and then it stops and all the lights start blinking! We have tried unplugging it and checked the drain hose but it still won't work. Please help me
  • Natasha Talkington Sep 14, 2007
    Ours has a display box that shows how many minutes are left of the cycle and when the door isn't closed all the way a CL comes across the box. That is not happening. The washing, drying, clean, sanitized lights are blinking and it won't run through a cycle. The display isn't showing anything.
  • Anonymous Mar 27, 2014
    DMT300RFW
  • 44 Answers
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Posted on Sep 14, 2007
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Electrolux PLD2560LCC1 lights flashing
Good Morning Friend,
I understand that you have flashing lights on your Frigidaire dishwasher, model# PLD2560LCC1, and will not start the cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try running the cycle again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher fdbb2840ec0 cancel button doesn't work
I understand that the cancel button is not working on your Frigidaire dishwasher, model# FDBB2840EC0. I also see that your appliance will start, but has to fully cycle before stopping, even though the start and cancel button are the same. I suggest resetting your dishwasher, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 22, 2014 | Frigidaire Dishwashers
Dishwasher wont completely drain and turns off
I understand that your Frigidaire dishwasher shuts off near the end of the cycle, leaving water in the bottom of the tub. I also see that the display is going black. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. When power is restored, run any cycle. If you are still noticing your dishwasher shutting off towards then end of the cycle and water being left in the tub, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off and not drain. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire Dishwashers
Frigidaire FFB240 dishwasher won't stop
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire FFBD2406NS Built In Dishwashers
Dishwasher malfunction
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
Frigidaire dishwasher shuts off mid cycle
Hello - From what you are describing it appears that the unit is attempting to run the cycle, but the wash motor is not coming on. Either the wash motor has failed or there isn't any or isn't enough power supplied to the wash motor. I personally recommend contacting a service provider to accurately diagnosis the dishwasher and to assist with the repairs.
Feb 22, 2013 | Frigidaire Gallery FGHD2433KW Fully...
How do i reset the cycle programme on my ADG 954 Dishwasher
Hello
Wait for five minutes if the motor stopped itself and has been stopped for less than 10 minutes. This occurs in the event of an overload. If this is the case, the dishwasher will reset itself in approximately 5 minutes.
Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
Repeat step 3. This will reset the dishwasher.
Aug 11, 2011 | Dishwashers
My dishwasher is starting it's cycle, then running for a minute or 2, then it stops and drains itself, then starts the cycle over and repeats this. It won't continue it's cycle and it seems to be stuck in...
you seem to be stuck in a 'quick rinse' cycle. double check your buttons as well as your timer/dial to see if you are using the normal wash cycle. especially check the buttons. good luck
Nov 02, 2009 | Frigidaire Dishwashers
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
889 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
