Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to access the projection lamp on magnavox model 50ml8105d
How to change the projection lamp on magnavox HD TV model # 50ML8105D
    Scholar:
  • 124 Answers
Go Here.
http://www.retrevo.com/support/Philips-50ML8105D-TVs-manual/id/277ag615/t/2/
Download manual. Should have info you need.
Hope this helped if I can Help further Please MSG Back.
Posted on Mar 12, 2009
  • 201 Answers
  • John Aman
    John Aman Mar 12, 2009
    If you found a solution that helped you, please rate it - if you have further questions, please feel free to post them.
    Thank you for using Fixya!!
    Top Expert:
  • Philips Master
  • 77,169 Answers
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear.
My magnavox dlp tv model 50ML8105D\17 will not turn on
First check the lamp, if not then maybe one of the fans is running poorly. Make sure it is plugged in.
Nov 13, 2011 | Televison & Video
Need owners manual for Magnavox TV, Model No. Pr1914C122
Just follow basic instructions. Hope that helps!
Feb 28, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced lamp in magnavox 50ML8105D/17 and now I only get sound for about 10 seconds with no picture then the tv shuts off
I would double check the install of the Lamp and also make sure the Lamp door is closed tightly and secure.
I hope this helps,
Skyassoc
Nov 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Aug 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox model 50ML8105D/17 shuts down after only a few seconds and overheat and lamp failure lights come on , I`ve replaced the lamp , but the problem still occurs
We reduced the picture size to 4:3 and was able to get quite a bit more life out of the lamp, without it shutting down. It does take awhile to get use to. But is much better than a dust catcher
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
