Question about Kenmore Dryers
My dryer mod. 417 98042701 won't heat. this started with the lights flashing on the front of the dryer
The lights on the front controls have been flashing for a couple of weeks. It would shut off too soon, but it would heat back up when you turned it back on. Now it will run but it won't heat up. You can't hear the gas kick in. The lights are still flashing. Tried unplugging and plugging back in. That didn't work.
SOURCE: Kitchenaid KGYS750LQ Drying very slowly
Fixed myself after talk with parts counter guy. One of the gas valve coils fails when they warm up. Repair kit comes with both.
1.) Unplug dryer. 2.) Remove dryer front panel. 3.) Remove the two screws on the coil hold down bracket. 4.) Slide one up and off. Then the other. Don't mix them up, one has two wires in slide connector, the other has three. 5.) Reinstall coil hold down bracket and front panel.
Fixed my problem. My cost was $17.00+tax. My part #279834.
Posted on Jun 19, 2008
SOURCE: Whpool gas dryer turns but it is not heating up. Mod # GGW9878PWO
coil starts and then cools down
Posted on Jan 18, 2009
  • 77 Answers
SOURCE: dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Posted on Apr 21, 2009
SOURCE: Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Posted on Oct 06, 2009
  • 107 Answers
SOURCE: Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Posted on Nov 12, 2009
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
Mod 417.94052500 won't heat
Have you tried to watch or listen to see if you hear it ignite and then it goes out or does it not try to ignite at all?
If it doesn't try to ignite at all, replace the igniter with this part.
If it ignites and goes out after a few seconds, replace the flame sensor with this part.
Oct 19, 2012 | Kenmore 77632 Gas Dryer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
see this causes and fix it. God bless you
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a 2004 Silverado 1500. The rear lights won't turn off, pulled all the fuses associated with lights and they still don't turn off. In addition my right turn signal doesn't flash, both the...
Not sure, but I've heard a bad hazard switch can cause strange problems.
Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
Jan 26, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
