Question about GCC Technologies Elite XL 40N Laser Printer
How do I refill gcc elite xl 40n black toner?
The cartridges no longer seem to be available and I will need to refill the existing cartridge. Help! this was an expensive laser printer
5 Suggested Answers
acdr
  • 1913 Answers
SOURCE: GCC Technologies Elite 12/600 Laser Printer Vista Drivers
download frok here
http://zxcdrivers.co.cc/windows-driver-196.html
just enter right code then clik on download.
Posted on Feb 07, 2009
SOURCE: Need the GCC Technologies Elite 12/600 Laser Printer Vista Driver
It is not available as a download to to it's age. Have you gone through the add printer wizard to see if it is pre-installed with Vista?
Posted on Feb 14, 2009
SOURCE: I've got a gcc elite 600 laser printer, used to
right here http://gccprinters.com/support/doc/elite600.html
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: new toner less than 3 months old,typcial usage 12-15 mth.608xl elite gcc printer. 1/3 page dark rest lt. print. Already cleaned mirror & reshaken toner
Email d_atwood@gccprinters.com for a solution.
Posted on Apr 28, 2009
I run windows 7 64 bit i need a driver for a ccc elite xl 608 laserprinter
If you have a Windows XP x64 CD, try the GCC SelectPress 600 or Select Press 1200 driver. The SelectPress 1200 worked for my Elite XL 20/1200. I believe the only 64-bit drivers that are available for GCC printers are on the XP 64 disc.
Dec 09, 2010 | GCC Technologies Elite XL 20/600 Laser...
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Replaced toner cartridge and now get printout of
try to reinstall the printer driver. then align the printer toners. then perform some test print.
Mar 08, 2010 | GCC Technologies Elite 12/600 Laser...
After putting in a new toner it only prints black pages
Seen this in HP and Brother lasers; I have no reason to doubt it is the same for yours. You have a defective toner cartridge; return it to the place that you bought it for an exchange.
Feb 08, 2010 | GCC Technologies Elite XL 20/600 Laser...
Ml1640keeps on glowing the redlight and docs are not get printed
please dear it is problem your printer toner unite because it has a emage chip in toner it is disavle to print. it is not riffill you change this toner and buy new one original samsung toner then solve your problem
Aug 02, 2009 | Samsung ML-1640 Monochrome Laser Printer
Fuser is bad...actually, the paper jam sensor is bad. can I use a fuser from a different printer
Yes, most likely they do. I don't believe there is much if anything that differentiates one toner from another other then the size of the roller and the shape of the cartridge. If these are the same and given that they use the same fuser, I would definitely try it.
Aug 08, 2008 | Xante Accel-a-Writer 4G Laser Printer
Epson Aculaser C1100N - Black Toner problem
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
Nov 18, 2007 | Epson Aculaser C1100 Printer
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
GCC Technologies Elite XL 40N Laser Printer Logo
77 people viewed this question
Top GCC Technologies Office Equipment & Supplies Experts
jasbo
jasbo
Are you a GCC Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
