Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Will fill bottom then hums
I have kudmoitjbso dishwasher hooked up will fill bottom with water then hum thats all ,the s.n is fk 3901737 can you help ?thank you
  • 478 Answers
Check to see if something is caught in pump or in bottom of dishwasher stopping the arm.
Posted on Mar 12, 2009
Dishwasher fills with water. then hums but dosen't clean
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher does not work at all. It just makes a slight hum.
Welcome to FixYa.
It sounds like you may have a faulty fill valve or a stuck motor impeller. I guess the first obvious question is, Does the unit fill with water ? If no and it hums, faulty fill valve or water supply is off.
If it does fill with water does the humming begin after it has filled, and if so has the unit recently been idle for a period of time...say a couple of weeks or so ? If yes, the wash impeller has become stuck and there is a simply resolution for Bosch dishwashers, it's a common occurrence.
These are relevant questions and can point directly to the problem if you want to reply I can help you move forward.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch SHU9915UC Dishwasher
Washer will fill with water but will do nothing else
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, try to hear a different sound like a hum/buzz/click sound. If it is like a hum sound from the bottom panel then it indicates that the motor is bad and needs replacement and if the hum/click comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Magic Chef Dishwashers
Dishwasher fills with water then hums
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | KitchenAid KUDS50FVSS Builtin Dishwasher
Humming noise after water fill and will not wash
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
239 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
