Question about Ricoh Office Equipment & Supplies
Ricoh FT-4527, E541 error. I know that the hardware relating to this problem is the fuser, lamp, fuse or fluctuating voltage, but I don't know the key strokes to remove the error code after the part has been replace or where to get this information. Does anyone have a good Ricoh source for the FT-4527, codes, and processes to clear them? Thanks very much.
  • imok66 Mar 15, 2009
    Thanks for the help with the copier, but I got it fixed over the phone, just by telling the user what to enter. I don't believe that he should have paid $130.00 for someone to just walk in the door and look at the copier. I'm a small PC/Equipment repair business, so I don't feel bad for the big, over priced guys. I have a tech friend that happens to work on copiers now, so he gave me the two missing code #s. It took 30 seconds to get the copier up and running once I had the correct numbers. The other option was to clean the waste toner from the thermistor which probably overheated when they moved it. If anyone needs help with the codes I have a sourse and would be happy to share my knowledge with them. I don't "cut my losses" easily, that's what makes me a good tech. It seems that sandmanmac needs to study up on his Ricoh copiers or stop giving copy machine advice.
....Nor do you have the parts. I answered you earlier today. If it were a simple fix/ adjustment I'd be happy to provide it. You need a trained technician, and only technicians will have the codes. You can find yourself in even bigger difficulty messing with service procedures that you know nothing about...cut your losses.
Posted on Mar 12, 2009
  • Anonymous Mar 15, 2009
    "Sandmanmac" has been a self-employed Ricoh tech for 13 years, and has provided solutions on hundreds of equipment problems here, as an act of good will. I do not not post 'service mode' adjustments on an 'END-USER' website, because that's "inappropriate" for the reasons stated above, nor am I about to take the time to write out specific instructions on how to remove and service a fuser unit. I gave the answer to the original question, which was in response to the "SC" number stated. My response to the FIRST POST was as follows:
    "It is a fuser error (low warm up temp), often caused by fluctuating
    voltage.You have a blown fuse, lamp, or thermistor. Can only be reset
    in service mode after the problem is solved.
    It can be viewed here:
    http://www.fixya.com/support/t1779285-er...
    I also stand by my reponse to the RE-POST, suggesting a technician was required. GREAT! You solved it over the phone via a 'technician"...I've done the same for dozens of my own clients too!
On the charge 2 I asked how to set the correct time your response was first to press the menu where is the menu?
YOUR Question wasn't answered. You are reading a RELATED QUESTION, and these may or not apply to you. The are offered automatically as possibly being of use.
This is that post.
http://www.fixya.com/support/t25941222-change_time_phone_power_max_5_8
Jan 10, 2017 | The Office Equipment & Supplies
How to resolve colour misalignment in ricoh c4000 prints
get to the device manager and do an alignment for the printer
Jan 09, 2017 | Ricoh Office Equipment & Supplies
I need a Ricoh MPC3002 Owners Manual?
Try Googling (ricoh)(MPC3002)(manual) without parens.
Sharp ar gives me error number h4 how to let it work again
The error H4 stands for the heater roller H3 (Fuser) temperature is low and probably burnt out. You need to call for service.
Jan 08, 2017 | Sharp Office Equipment & Supplies
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
How to turn 118.3 cu ft into inches?
118.3 cu3 = 24.0985 cu2 (square feet) 24.0985 X 12inches = 289.182 square inches.
http://www.endmemo.com/cconvert/ft3ft2.php
It might be 118.3 cu3 X 12 inches = 1419.6 cubic inches
Not quite sure what you needed.
Dec 21, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
I don't know to to program my avery berkel ix 202 help
This is your machine here.
https://www.cashregisterstore.com/pdf/IX-100-202.pdf
It has the contact details for Avery Berkel. Ask them to send you a PDF copy of the instruction manual or ask their service desk how to program.
They provide one here
http://www.averyberkel.com/media/IX_User_76103-831-05.pdf
Or you can download this one, also free
http://www.armaghpos.com/images/stories/Avery_Scale_Manuals/avery_berkel_ix100_scale_label_printer_om.pdf
Or buy one here.
https://the-checkout-tech.com/manuals/scales/Avery_Berkel_IX-110_and_IX-202_and_IX-212_user_guide_manual.html
avery berkel ix 202 Google Search
Mar 10, 2012 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
553 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
