Question about Toshiba Office Equipment & Supplies
Toshiba 2860 paper stops approx 1 inch befors entering fuser
Toshiba paper stops with a jam error.
Paper stops 1'' before enter fuser unit. All I did was replace the drum unit.
noting gets crumpled up copier just stops period. There is transfer on the paper after it leaves the drum unit approx 3/4 of copy job.
  • ronaldj588 Mar 12, 2009
    Toshiba 2860 copier
    the copier issues a jam signal before the transfer is complete. The trailing edge of the paper is still in the transfer process when a jam signal is issued. This is the first page every time. Not the 2nd page. Copier will stop with a jam signal on the first page. there is approx 1 inch or less left on the trailing edge still under the imaging drum.
  • 527 Answers
Sir,
Due to worn lower fuser roller bearings.  You can try oiling them and clean the roller it will be solved.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 12, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..The density sensor (under the drum) also doubles as a
paper path sensor. Toner frequently clogs it up and it can't
see the paper. This usually results in code 8-12 jams and
1/2 copies being output to the tray. Just clean the sensor
and run routine 9-71. This will set the reference for a clean
sensor against a toner patch on the drum. If you have trouble
setting this routine, you may have to adjust the ADC pot on the
main board and try it again. Sometimes this sensor goes bad
and needs to be repaired or replaced. There aren't many components
on it so you can usually repair it fairly easily.
check this out..
thank u..
    Sergeant:
  • 320 Answers
Get your printer serviced some dust partickles are blocking the paper to move further.
    Sergeant:
  • 254 Answers
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
  • ssolved Mar 12, 2009
    the printer paper sensor is broken it needs replacement.
    get it replaced no other option.
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Our HP 4250N Laser Printer is leaving a black line approx 2 inches off left side of paper. Tried cleaning rollers and putting printer into clean mode. Nothing is working. Any advice? Thank you.
This is caused either by the fuser or the tonercartridge.
The most common cause is the tonercartridge.
You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
If the black line is there before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
Jan 04, 2011 | HP LaserJet 4250n Printer
Toshiba 2860 copier, paper does complete the transfer process.
Did you get the drum shaft reinstalled and latched? If not, the drum won't rotate correctly which will cause poor transfer (smudged image) and jamming.
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
Toshiba 2060 Paper Jam at the fuser
I would have to say that you are missing the fuser drive. I would remove the fusing unit and look to see if you are missing any gears or any missing teeth from a gear or just missing a gear...
Jun 18, 2008 | Toshiba 2060 Copier
52 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
