Question about Samsung TXM3296HF 32" TV
Philips hdtv color distortion
We have a 55 in philips hdtv projection tv that was made in July 2002. The picture is clear, but colors are distorted... the greens and reds are separated. Not sure what this could be or where to even adjust it. Any advice is appreciated
    Genius:
  • 1,074 Answers
Your tv has a prolem in the color circuit there is a ic that controls this circuit changing it will restore your tv to normal.since you are not a tech have a tech look at it for repairs.good luck.
Posted on Aug 04, 2007
SOURCE:
We cleaned the lenes and put new bulb in ,put the tv back together and the picture to colors like voilet color and a bright yellow took it apart 3 times..dont know what else is wrong
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 06, 2011 | Philips 55PL9524 55" Rear Projection...
58'' TV IS SHOWING ALL RED
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 21, 2010 | Philips 55PW9363 55" Rear Projection...
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Bluring of colors
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
Apr 09, 2010 | Philips 55PW9363 55" Rear Projection...
How to make the picture to a Philips 2002 rear projectiontv clear
needs to replace the liquid in the tubes of blue and green projection
Jan 06, 2010 | Philips 55PW9363 55" Rear Projection...
The color on my 55
Change the coolant fuild in R/G/B Tubes.
Dec 30, 2009 | Philips 55PW9363 55" Rear Projection...
Picture is doubled and multi-color
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Oct 20, 2009 | Philips 55PP9363 55" Rear Projection...
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 55 inch rear projection tv
When it is on, do you see any distortion in color?  If not probably bad power supply board. Call 1-800-543-4330 and have model and chassis number and ask for Power supply/deflection board. Only about 200.00
May 29, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55PP9401 ProjectionTelevision
it seems as you need your tubes re-alinged dont get riped off by tv experts saying it will cost you loads if you have a screw driver and a gentl touch just re focus your red green and blue-simple cost you nothing
Aug 08, 2007 | Philips 55PP9401 55" Rear Projection...
Samsung TXM3296HF 32" TV Logo
387 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
