Question about Royal 112MX Shredder
My paper shreedder is not working
Nothing is aorking
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
Im trying to get a .cer app for this phone but I tried all the numbers behind the battery and they dont aork as IMEI where can I find it?
The IMEI number is uniquethe each mobile phone. The number is printed onthe label under the battery. You can also get theIMEI number by entering this on your phone *#06# It will then display your IMEI numberand you may also get a unique global serial number. Your IMEI number should be15 digits.
Mar 10, 2011 | Cell Phones
1995 BMW 525i. Car will not start or turn over. Have lights battery is strong, replaced starter, starter was tested, and worked. When ignition is turned dash lights up but starter does not engage. Have...
I had the same problem, after having the car towed to four Seasons, it was discovered that the electrical portion of the ignition switch was defective. Works like a charm. Part number 61 32 8 356 026 Hope this will help.
Feb 06, 2010 | 1995 BMW 5 Series
Remote does not operate ceiling lights or fan.
Hi fan was aorking fine then when u first turn fan on it made nosie .Now fan or light wont come on , i check power its fine
Oct 31, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
My laptop says there is no sound driver installed. it was aorking fine till now what do i do
Well first check device manager and make sure it is not installed, secondly identify if there is any unknown devices in device manager, if not then the device has either been disabled or is having a serious conflict, now reboot the computer and while its rebooting check the bios to see if the peripheral devices has the onboard audio disabled, if that is what it is, then after it reboots double check the device manager and make sure the device has not been reinstalled and there is not any unknown devices.
Oct 29, 2009 | LG X-Note LM50 Notebook
Nothing prints on paper
Kodak printer 5500 make out photos with UltraPremium Paper very flashy even with darker photos shots,
tried calibrations with photo paper kodak says: no suitable paper format
Feb 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have a kenmore side by side refrigerator from 1988 model number 3638597780 serial number b8512188. i dont know what the model is. it has 27 on the door handle. the back wall in the freezer will freeze to...
is the evaporator fan working correctly? Alsso is the drain line clear? those arethe things to look at first. if they are aorking properly then check to see if the damper are not in a bind or stuck. Good Luck with this.
Jan 06, 2009 | Refrigerators
Out of paper, but really note
I have the same problem....I look for and you have to change the part inside the printer that pull in the paper..I was having the same problem and it works...any question my email is yg-ag-69@hotmail.com.
Jan 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
Nothing prints on the paper
My Printer is doing the same thing try to print color and see if the color works im color works but only in pink
Oct 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Royal 112MX Shredder Logo
29 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
