Question about Humidifiers
My forced air central humidification system does not work
The water is flowing through the tube from the water heater to the humidifer unit but there it stops
  • 478 Answers
You need tocheck for power at solinoid valve or continuity of valve where water enters the unit. THe furnace must be on and humidistat calling...
Posted on Mar 12, 2009
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
Waterless code displays, but it is full
the inlet valve spring is too strong on these, so the water can stop flowing into the unit. makes sure it is on a flat surface, fiddle with the valve spring.
Dec 14, 2013 | Air Innovations Ultrasonic Digital...
I just moved iinto my new home. I have never owned a home with aprilair 560 unit. I just got it fixed I hope. But I put a new water filter in monday the 27th. How often should you replace it. ...
It is a bypass humidifer the pad in it should last a couple of years, the water runs over the pad and air pulls moisture off the pad. Putting it into the home. Make sure the damper is open for proper air flow.
Dec 30, 2010 | Aprilaire 550 Humidifier
Airconditioning is making baby cough and nose run would a humidifer help? will a humidifer make the room hot?
You may need a HRV/ERV installed. Depends on your indoor air quality(IAQ). It may be allergies. I would talk to a reputable heating/cooling contractor in your area to evaluate your system, recommendations.
Nov 21, 2009 | Aprilaire 600 Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
Continuous water draining from my General 1042 Humidifier.....
This type of humidifer is known as a flow through humidifer, when running water flows through it instead of sitting in a pan. The water draining is normal. This type of humidifer will use more water than a pan type but is much healthier due to the fact that you do not get all the build up of the pan type if you ever cleaned one. also change the water panel every year. to change the water panel there will be 2 screws on the bottom pan. Remove them and the panel will come out, buy a replacement at home depot or such store if available, otherwise from a htg company. Replacement is a little tricky to get it to line up so be patient. If you cant remove the bottom panel due to lack of room, it will come out through the top. You will have to loosen and swing the water feed tube out of the way. That is the only maintainace to this humdifier. Also with this humidifier all you have to do is turn the humidistat to off in the summer, you do not have to turn off the water as with float types. Steve
Nov 28, 2008 | General Filters 1042-LH Humidifier
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Humidifiers Logo
573 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
