Question about HP LaserJet 5500 Printer
HP LaserJet 5550 Dumping Excess Toner...
My config pages are ejecting looking like christmas trees because the magenta, cyan and yellow have all deposited excess toner on the page indescriminately. Except blank lines run across the pages in roughly 10 areas where I'm thinking toner is scraped off prior to entering the fuser. I have replacement toner carts. on the way to insert tomorrow (this won't fix the scaping issue but hopefully the dumping issue) after another thorough cleaning.
Unfortunately, another cool occurance is toner is collecting on the transfer film (for lack of another term) so the rear of my pages, after they exit the fuser, are multicolored on both sides.
  • 1 more comment
  • Novice_Domo Mar 12, 2009
    Thanks tonersmart for confirming my assumption. After cleaning, even though as you say it should clear-up by itself I should tidy up one of my users printers.
    I was getting a reading on the display earlier when I removed and replaced the magenta and yellow carts a showing of -
    Bar Graph... ?... ?... Bar Graph
    so to me that means that the printer was reading the black cart but not the magenta or yellow and then it read the cyan. My plan is to clean the contacts also but I'm hoping any communication problems were with the problem carts.
    No worries about the compressed air, I save that for equipment that doesn't have sensors.
  • tonersmart May 11, 2010
    I do not understand what you mean by "bar graph".
    You have bad cartridges or old cartridges. When the cartridge leaks, thats the only way you are going to get anything on the BACK of the page.
    You put genuine HP carts in it, or QUALITY remanufactured carts, your problem will stop. Don't clean the transfer belt with anything. It will get rid of built up toner on its own. At most, use a soft tissue to clean off the crud on it.
    As far as the scraping goes, run a print, open the printer door just when the paper is midway. It will be in there stuck to the transfer belt. You will see the print defect on this UNFUSED image if theres something rubbing before it gets to the fuser.
    DO NOT USE COMPRESSED AIR TO CLEAN OUT YOUR PRINTER, it will get on the laser scanner optics.
    Genius:
  • 1,089 Answers
Are you using HP toner?
Pull out the cartridges and vacuum out the printer. Get a compressor or canned air and blow the printer out. Vacuum again,
Install HP toner and try printing again.
Posted on Mar 17, 2010
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Took out drum, and yellow cartridge to release jam, cannot get yellow back in
On the topmost part of the printer, there are four buttons in the following order (top to bottom): Black, Cyan, Magenta, and Yellow.
Besides the four button is another button with 4 dots (Black, Cyan, Magenta, and Yellow with a rotating arrow), press this once and you will see that the Yellow button on the left will light up, press it again and the light besides Magenta will light up and so on. Anyway, you get the idea.
Just keep on pressing it until the light besides Yellow lights up again. When it does, lift the top cover of your printer and insert the yellow toner.
Jun 03, 2010 | HP LaserJet 2550L Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
Hi there, need your kind help. My Hp laserjet 5550 has a missing colour problem. Cyan is missing in the print out, giving rise to to blue and green colours being absent in print-outs. Scanner is confirmed...
Cyan cartridge is OK, means that the display shows the level of toner in the cartridge, right? Then chip it is ok.
Try another cyan toner, the printer may be that it has broken the opening flap of the laser. Or check if the laser's flap cyan is blocked.
Nov 14, 2009 | HP LaserJet 5550 Printer
On Initialization the following error appears 10.00.01 Supply Memory Error.
The printer cannot read the memory tag on the black toner catridge. Power the printer off, swop the black toner cartridge for another colour.ie put the cyan, magenta or the yellow in the place that the black should go and fit the black in to space left by the colour. Power the printer on and see if the error remains the same.If it's the same error then it could be the cartridge reader in the black position.If the error changes, then it's possibly down to the black cartridge.
Oct 14, 2009 | HP LaserJet 5550 Printer
Newly replaced original magenta toner not printing
Dear this printer is solve this problem just
chnge the magenta toner scaner ok ........after that is working but ...do not any idea about this just call me :+91-09328015664
and Email:support@compudesk.in
Jul 14, 2009 | HP Color LaserJet 2600n Printer
Color washed out
Hello sir; Try to clean out scanner mirrow, see what happen!
Apr 16, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 5500 Printer Logo
386 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
