PrepareInf error 2 phillips SPC650NC - Computers & Internet
Add Phillips headset to HP laptop with Windows 10
how to plug it in? (add?) how to make it work,? and use it?
what head set.? the Phillips model.
USB, or the 2 mini plug type, (2 plugs , 1=head phones, 1= mike)
What is the Phillips part number there.
head sets come in 3 class types.
1: wired. 2,miniplugs
2: USB ( has built in sound chips)
3: bluetooth or with USB to add blue tooth.
what PC? windows 10 sure, but what PC?
Apr 16, 2017 | HP Computers & Internet
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I tried the link bellow to install the dynex dx wc 100 camera but i keep getting an error message when it get's to 70% of the download taht reads "PrepareInf Error 2" when i click ok or close the message...
The File setup in folder DX-WC101 (or 100) extract with.WinRAR.. In new folder "Disk1" file "setup" go to "propertys" and choose "compatibility". Put Windows XP with SP3. It's all, start installation. Will all 100%! Sorry for my English :)
Sep 05, 2010 | Dynex DX-WC100 Webcam
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
Error E71 ?
Hello, When you get the dreaded Disk Read Error, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Tools required by this guide are (not all are required for all parts however):
1) A normal sizes star (Phillips) screwdriver.
2) A very small Phillips screwdriver.
3) A small, flat screwdriver.
4) Some isopropanol alcohol (IPA)
5) A few cotton buds
6) A little mechanical grease. (I’ve used Vaseline before)
7) A can of compressed air.
8) An oscilloscope.
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
May 19, 2010 | Microsoft Xbox Console
Not allowing to record.Comes up with disc error
if you use a phillips brand audio recordable blank it should be no problem
Feb 24, 2010 | Philips CDR775 2-Disc CD Recorder
Phillips magic 5 voice dect fax
phillips magic 5 dect fax showing ''1 pending error''
cant remov e it
Nov 16, 2009 | Philips Office Equipment & Supplies
GE EasyCam has an Error at 100 pct downloaded PrepareINF why?
Normal 0 Additional info further down.
GE PC Cam Drivers
http://www.jascoproducts.com/support/software-downloads.asp
Then
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps
Mar 31, 2009 | GE EasyCam Webcam
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Feb 02, 2008 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
