Question about Octane Fitness Q47ci Elliptical Trainer
Octane 45e error 3 - Octane Fitness Q47ci Elliptical Trainer
Is Premium and higher octane better than regular gas in Mazda 3, 2012 car?
Octane ratings have nothing to do with fuel economy or power. The octane rating only indicates how much the fuel air mixture can be compressed before it ignites without the spark plug firing in a hot running engine. Some really high compression engines require higher octane fuels so they don't knock when running. If you don't have a sticker under the filler lid that says you have to use one of higher octane fuels, then don't use high-test.
It used to be that using a low octane fuel in an engine designed to use high octane fuels could damage the engine.
Nowadays, engines are all computer controlled and most high octane engines will re-tune themselves on the fly so that they don't knock if the wrong grade of fuel is used.
Feb 20, 2015 | Mazda MAZDA3 Cars & Trucks
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
Ecoped 45E Repair manual
We have no repair manuals for this type of product, they are copyrighted and not available for free downloading at any site.
Jan 31, 2012 | Cars & Trucks
1998 S-10 cold start
The cold weather wreaks havoc on everything. I am thinking that the cold weather and your octane rating are not getting along, hence no error codes. Have you tried fuel drier and or octane booster?Since the truck starts when the temperature gets warmer, I would look at octane as the culprit. Try some octane booster and see if that helps. Let me know. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 26, 2009 | 1999 GMC Jimmy
I have a r33 skyline and if i give it full throttle it pings but not at 3/4 throttle? how do i fix it?
What fuel are you using? If you are normally running 87 octane and it's pinging, try a higher octane for a while. I know it's still pricey but some cars require the higher octane. It may take a few hundred miles to run all the 87 octane out of the system so try running for a month on Super. Just a suggestion. Hope it helps.
Jan 07, 2009 | Nissan GT-R Cars & Trucks
Right side Toyo 45E post guides
Chances are slim that you will find anyone with the parts. As a camera repairman, I would have never stocked those parts, trusting the distributor, in this case MAC group, to provide them when and if I ever needed them. I don't have a parts diagram for that camera to look at, so can't advise about the cost to "fabricate" the post guides, but short of finding a dead 45E to salvage from,it might be your only hope
Dec 24, 2008 | Toyo -View 4x5 45CF Field Camera with...
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
Octane Fitness Q47ci Elliptical Trainer Logo
55 people viewed this question
Top Octane Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
