Question about Dell Latitude XPI Bottom Plastic Cover - 99354 CD-ROM Drive
I'm using the telephone to connect with the internet but i can't find the port that the phone jack goes into. does anyone know where/how i can download that info like an owners manual
    Problem Solver:
  • 19 Answers
Are you trying to download a manual?? if you are connected to the internet to post this, then what are you trying to hookup. i would love to help you out. good luck
Posted on Mar 12, 2009
When I try to send a fax on my lexmark x4650 it has error no dial tone?
If you are getting "no dial tone" as an error on your fax machine, it means that you have the telephone cord plugged into the wrong port on it.
Turn the printer around so that you can see the back of it. If you look closely, there should be three ports to choose from in which you connect a telephone cord. Sometimes they put a little white plastic piece in the ports to keep them clean during shipping ect. If this is the case, go ahead and remove them now.
If you look closely at each port , you might notice that they have text or pictures right above or below them to tell you which one to use. let me explain; if you have one telephone line and wish to use it for both fax and voice calls - you will need more than one port. That's why they mark them.
One of the ports should say "line" or have a picture with a funny little symbol on it. This is the port that you would use if you want to fax someone using your printer. You plug your phone cord into this port on your printer.
One of the ports should say "phone" or have a picture of a telephone by it. This port is used when you want to share a single phone line with both your fax machine and telephone used for making voice calls. To split your line between both fax and phone, you plug your phone cord from the wall into the port marked "line" and take a second phone cord and plug it into the port on your printer marked "phone" and the other end of that line goes into your telephone (voice line).
The last port should say "line 2" or similar and usually has no picture next to it. This is an additonal port to share with a second phone line.
To correct your problem of "no dial tone", plug your phone cord into the socket on the wall and put the other end into the port on the printer that says "line". Now lets test the connection.
Put a piece of paper into your printer, press the fax button and dial any phone number using 1 and then the area code followed by the phone number and press 'start" or "ok" to begin the fax. If you have chosen the right port to connect your telephone cord, you will hear a dial tone first, and then dialing of the numbers you chose. If you cannot hear a dial tone before your numbers begin, then you have not chosen the right port. If this is the case, remove the phone cord from the port you have chosen and try another until you do hear the dial tone.
NOTE:
Do not try to go from your phone jack into your telephone and then use a second port on your telephone to connect a second phone cord that is plugged into your printer/fax. A second phone port on your telephone is most likely for a second phone line to use for voice calls. The majority of phones for residential use do not have a built in splitter that works like a fax/printer does. If you try to use a second port on your phone to split to your fax machine, it usually will not work. Follow the instructions as listed above to re-route your line and correct the problem.
MAGIC JACK USERS:
While magic jack is great for making free long distance calls, it is not suggested for use with a fax machine. if your trying to use your magic jack phone line to fax it usually does not work.
Jul 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Wiring schematic for this router
Jehayman,
I am not if you are referring to the Ethernet connection when you said connections to the telephone line. Your WRT54G does not have a telephone port, it has an Ethernet port. If you would like to know how to connect this router to your network here is how you can do it.
If you look on the back of your router, there will be 5 Ethernet ports there (looks like a phone port but it's bigger). They are labeled 1,2,3,4, and WAN or Internet.
The ports labeled 1-4 are for your computer/s that will connect to the router through wired connection using an Ethernet cable. The port all by itself labeled WAN or Internet is where the modem should go to. If you dont have a modem from your ISP and just have a line that is plugged in straight to the computer, that line can be plugged in to that port.
Feb 07, 2010 | Linksys Wireless-G WRT54G Router
How do I set it to receive a fax? I'm working in an internet cafe and people are trying to send me a fax but it won't let me. How do I do so?
Use a 4-wire telephone-cable to connect the telephone-port on the unit to a live telephone-jack in the wall.
Use your cell-phone to "dial" the telephone-number associated with that telephone-jack. Listen on your cell-phone for the unit to "ring" and for it to "answer" the telephone-call. If it does not answer, check the configuration on the ALL-IN-ONE.
Dec 11, 2009 | Brother MFC-8460N All-In-One Printer
How to connect multiple phones to voip adapter? Only line 1 is available for connection.
Have you tried using a 5 or 8 port switch to see if this will allow u to have 8 or 5 more phones available ...they do make a 25 switch if you want to add 25 phones
Sep 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
No internet
You need to check if its a Modem enabled, if its a dialup u need to call the ISP and reset the settings and if its a Modem and DSL u need to use the cable fromthe modem not the telephone cable directly.
May 17, 2008 | Compaq Evo N610C Notebook
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
May 09, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
