Question about Whirlpool LEQ9858P Electric Dryer
My dryer was working fine last night, then today, no heat. The vent is cleaned, nothing in there...heating element?
    Scholar:
  • 124 Answers
Heating element maybe not likely.
Probably thermal switch overheat protection tripped.
Try putting in lower heat mode (touch up or permanent press) see if you get heat.
Some thermal switches can be reset most have to be replaced. $20.00 to $45.00 Plus labor $??.?? to $???.??
Hope this helped. need more help MSG Back. Please rate. Good Luck!
Posted on Mar 12, 2009
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Burning smell however, motor runs fine, belt looks good, element heats up, vent is clean. i'm at a lose
Dryers collect lint.
Some, like the one I fixed last month, had a whole wastebasket full of lint inside it where you could not get it out without tearing the whole dryer apart.
I\'m suspecting either lint or some other foreign object is burning.
For your safety, please take it completely apart, or get someone else who knows what they are doing to do so, before you have a dryer fire.
( P.S. The last dryer I just fixed had a worn out felt on the drum, allowing the blower fan to suck lint past the screen and fill the inside of the dryer with that lint.)
Be blessed.
Apr 16, 2013 | Dryers
Burning smell however belt looks fine, element heats, motor turns vent is clean. I'm at a lose?
Check if the heating element is touching the heater box somewhere
and grounding it .
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Two problems with Whirlpool Dryer
I would suspect the heating element. I bet you are asking why this clown is saying that when you already told him that on high heat it worked fine. SIMPLE! Your heating element is made up of five coils. For low heat your dryer uses two heating elements and for high all five. So if one or two of the heating elements are open and they happen to be the low temp dry setting ones, that would explain it. That model doesn't have the dryness sensor on it (according to my documentation) so the heating element is the most likely cause.
Hope this helps!
ImJustAvg aka Hal
Dec 30, 2011 | Whirlpool Dryers
WHEN I TURN THE DRYER ON THE HEATING ELEMENT HEATS UP. THE GAS TURNS ON FOR 17 SECONDS THEN TURNS OFF.IN ONE MIN. THE ELEMENT HEATS UP AGAIN THE GAS TURNS ON FOR 7 SECONDS.
the most important think in a dryer is the vent that goes out side,if this is not clean the burner will keep going on and off,try this unplug the vent and then try it,if it works fine then you know its ,your vent clean vent,then put vent back on,all gas dryers have to be vented outside
Sep 12, 2010 | Dryers
My dryer stopped heating last night, is there an internal breaker for the heating element?
Yes. Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Oct 05, 2009 | Whirlpool LER4634J Electric Dryer
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Mar 06, 2008 | Dryers
Whirlpool LEQ9858P Electric Dryer Logo
182 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
