Question about Skagen Watches
Instructions for a 732xltlb-g skagen watch
This watch is radio controlled and not sure how often it will update as i dont have manual. can you tell me were i can get hold of a manual.
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
SOURCE: g force radio controlled watch instructions
I have an ehoward&co radio controlled wrist watch and I'm having difficulty in setting the correct time on the dial. can you help?
Posted on Aug 14, 2009
escapement
  • 2334 Answers
SOURCE: Radio controlled 3ATM watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please.
Posted on Mar 31, 2010
gemineye61
  • 831 Answers
SOURCE: Where can I buy replacement
Try this link:
http://www.skagen.com/service/orderWatchBandParts.fx
Posted on Aug 09, 2010
SOURCE: need a manual/ instructions for auriol 2-LD2970-4
Go to
http://www.2instructions.com/search.php?cmarque=AURIOL&modele=RADIO%20CONTROLLED%20WATCH%202-LD2970-4
Posted on Jan 27, 2011
Tip
SKAGEN watch manuals/instructions.
Here is direct link for all original SKAGEN watch manuals/instructions: http://www.skagen.com/service/watchInstructions.fx
on Jan 23, 2010 | Watches
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
Where can I find a manual for a Skagen 390LTR?
Put http://www.skagen.com/service/watchInstructions.fx into your search engine and you should arrive at a page which gives you a list of instructions you can choose from.
One of these should be suitable.
Apr 09, 2010 | Skagen 390LTR Wrist Watch
I have a Skagen that i cannot figure out how to set the time on. it has 4 different buttons and looks like it is designed to tell time in a variety of places.
You can get instructions for your watch by going to the skagen web site "skagen.com", choose your area.
At the bottom of the page you will see a number of menu options, click on "customer care" and then on "instructions" (under the heading "warranties").
There will then be a set of instructions for all their watches and you can choose the one that is similar to yours.
Jan 23, 2010 | Skagen 355LGSC Wrist Watch
Watch battery and manual for Skagen 271sgxd
try sending it to skagen they can fix your watch and you will still be covered under there lifetime warranty!
http://www.skagen.com/service/watchWarranty.fx
p.s. the manuals are all on this site as well!! thanks!
Jul 03, 2009 | Skagen Ladies - DEMI CRYSTALS LINK WATCH...
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
I dont know what battery goes into a Skagen 233LSS
send it to skagen for $15 they will look it over and replace the battery without voiding the lifetime warranty
Feb 01, 2009 | Skagen 105LTX Wrist Watch
Best way to clean my rosegold coloured watch ******** my Skagen watch
Unless it is totaly trashed, the best way to keep your watch looking good is to get yourself a jewelers cloth ( rough cloth) which you can buy at alot of jewelry stores, and jewelry departments at bigger stores. The cloth has a rough (a brightening agent) that when you rub it on your watch shines it up like new. Make sure you get a gold jewelers cloth ( not a silver one) since your watch is rose gold coloured) and usually you have to open it up becuse the outside is just a regular cloth and the rough is in the middle of the cloth. The instructions you get with the cloth should tell you how to use the cloth. Good luck!!
Oct 21, 2008 | Skagen Watches
Watches Logo
119 people viewed this question
Top Skagen Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
