Hi, if it is a new installation, possibilities are: 1. too tight, unit is partially squeezed preventing the CD from ejecting; or 2. internal problem, mechanical failure. Both requires that you slide it out of the bracket and test it outside the holding bracket but with the wires still connected. If the unit operates outside of the bracket/holder, then it's too tight, if it still does not work, then it is an internal problem which would require that you bring it back to the dealer for replacement or repair. If for whatever reason you would venture to opening it yourself or if you feel comfortable with tinkering, opening the top cover of the car stereo would expose the inside mechanism. Sometimes there is a latching lug or locking system that needs to be removed prior to actual installation. Sometimes, it's just plain r^r remove/reinstall. Hope this gives you some ideas and work out for you. Pls post again how things turn up. Good luck and kind regards.
I have a chrysler town and country lxi. I installed my Jvc kdr200 and it powers up but I have no...
(More)
I have a chrysler town and country lxi. I installed my Jvc kdr200 and it powers up but I have no sound. Can anyone help?
Bought my son a 9 YO Renault Clio and it appears the radio had been replaced with a different unit...
(More)
Bought my son a 9 YO Renault Clio and it appears the radio had been replaced with a different unit then the original (I assume) radio put back in when it was sold. The code in the book says 1218 but this does not seem to be accepted. I just get the beep and even when holding the 5 button for a further 20 seconds - nothing. The details on the radio are: Model 22DC259/62F Prod No FD0400370187460 TOB370 RN259FY0187460 8200029539TB370 Any ideas on what is wrong and how I fix it? Or is it a new radio for Xmas? Barry
When I connect my iPod via the external usb port, it brings up the iPod screen and the clickwheel,...
(More)
When I connect my iPod via the external usb port, it brings up the iPod screen and the clickwheel, says that the song is playing but does not produce any sound. I have not been able to figure out why, and I have gone through every setting on the unit...... Also, the EXT audio port will not function, I have a male to male cord plugged in and I get nothing. I feel like I am missing something
I just plug my Alpine CDA-9835 and when I turn on my ignition switch, everything works but not the...
(More)
I just plug my Alpine CDA-9835 and when I turn on my ignition switch, everything works but not the sound. What I do?
