Question about PNY Optima Pro 2GB Secure Digital Memory Card
How do i unlock pny optima memory card
I cant delete or add music to my sd card....is it locked or something?
lock123
  • 6831 Answers
SOURCE: Have brand new PNY OPTIMA SD HC 8gb
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
  • 10406 Answers
SOURCE: My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Posted on Dec 10, 2009
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Posted on Jan 07, 2010
  • 224 Answers
SOURCE: my pny optima sd memory card is reading card error
faulty i'm afraid, try the manufacturer for resources to get the data if any?!? good luck
Posted on Apr 06, 2010
  • 245 Answers
SOURCE: my pny optima sd card
Format the card. That will remove everything on it.
Posted on Dec 19, 2010
Testimonial: "Thanks. I wondered if that was what I needed to do. Formatting now. You're a true genius!"
My PNY Optima SD 2GB memory card locked itself! How do I unlock it?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 02, 2014 | PNY Electronics - Others
How to delete photos from sd through desk top computer
You will need to connect your PNY Optima to your computer Click start click on my computer to open from there you should see your PNY Optima then right click to select open you should see
the data / photo's in there select what you want to delete right click select delete or you can right Click select format this will delete all data on hard disk Hope this helps.
Dec 08, 2012 | PNY Optima Pro 2GB Secure Digital Memory...
How can i delete pictures on card
Click on start. Then choose windows explorer. Then find your memory card drive letter on the left side of the window pane. Click on the drive letter. When the memory card drive is selected then go up to the edit tab in the upper left and choose "'select all". Then hold down the shift key and hit the delete key on your keyboard. When it pops up asking you if your sure you want to delete the files click "yes". Just make sure it's the memory card files you are deleting...
Jun 30, 2012 | PNY Optima Pro 2GB Secure Digital Memory...
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
I have an Optima SD 2 GB card and I cant figure out how to download music from my Windows xp
You will need a SD Card reader such as this---http://www.newegg.com/Product/Product.aspx?Item=N82E16820223088&cm_re=sd_card_reader-_-20-223-088-_-Product
Just insert the card as instructed by the device and plug it into a usb port on your pc. A Autorun window should open asking what you want to do. Choose open folder to view files or something similar to that and drag and drop or copy and paste files to the drive.
Feb 20, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 11, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
Won't store max amount of memory
I tried copying music to my PNY 2GB, too, and it stopped accepting after about 720 MB. I deleted all the music I had on it, created half a dozen new folders, renamed them, then put as much music as I wanted on the SD. I haven't tested it on my phone yet but at least it let me copy all the music I wanted.
Apr 14, 2009 | PNY 2GB microSD Memory Card
PNY Optima Pro 2GB Secure Digital Memory Card Logo
141 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
