Question about Fossil Mens Atomic Big Tic Watch Box Set JR1210 Limited Edition
Cannot remove the band on my jr1210 black white rubber
I got the watch with no manual not sure how to switch to the black bezel any one know how? I've searched and searched nothing seems to come up on the watch only other models with totally different bands....
SOURCE: link removal
here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
Posted on Aug 10, 2007
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
SOURCE: Band adjustment
I was able to take use a push pin (thumb tack) to get out the (split) pin. I put the thumb tack in the hole of the pin I wanted to remove, place the thumb tack upside down on our counter top and gently but firmly push the pin out. It only has to push out an 1/8 of an inch and then you can pull it the rest of the way. Thanks to the diagram that "guest" posted above - I copied and pasted: http://www.pmwf.com/Watches/WatchSchool/WS%2014%20How%20to%20Resize%20Common%20Bracelets/WS%2014%20How%20to%20Resize%20Bracelets.htm#Split%20pin%20bracelets in the browser and it showed me how the pins work in the wrist band. Didn't need all of the fancy tools. (:
Posted on Mar 18, 2008
SOURCE: I need to know how
That means you can take the links out either way. Take a small pin that fits in the hole and lightly tap on the pin. If you find you have problems, add a LITTLE oil in the whole, this should make it easier, though a little messy.
Posted on Aug 03, 2008
escapement
  • 2334 Answers
SOURCE: Adjusting the Band...the damn screws!
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 26, 2009
I need to replace the bezel of my nautica divers watch from black to red and white combination . A151026 model
ALL NAUTICA WATCH BAND OPEN THIS LINK IN EBAY
http://www.ebay.com/sch/bluss_929/m.html?item=321576294387&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Feb 27, 2015 | Nautica Watches
My Purchased Movado is unusual and the band has cutouts which have fallen apart .How can I fins a replacement band ? The numbers on the back of my watch are84-G2-1883 second line 7010784.Cant find th
That is a beautiful watch. There are a few used ones being sold now on eBay. I think you have 3 choices. The best would be to bring it to an official Movado dealer and ask if it's possible to replace the band. You could also get a routine service at the same time. If they don't have an identical band, then check out what other bands would fit, if any. Lastly, buy one of the used ones on eBay and hope for the best. Good luck. (Now that I think more about it, I've seen a few other internet shops that specialize in band replacement. They aren't very easy to find but it might be worth being persistent and making sure you've exhausted your options.)
Jan 06, 2015 | Movado Watches
I need an instruction manual (user's manual)
Hello James,
I couldn't find an online documentation of the manual you are looking. But I did find instructions with a video on how to set the date/time of your watch here:
http://www.keepthetime.com/blog/instruction-guides/how-to-set-the-timedate-on-a-cartier-tank-francaise-quartz-chronograph/
I hope that will help you.
Nov 23, 2011 | Cartier Tank Francaise Chronograph White...
How do i know its a genuine watch has on the rear
where can i find a watch band for the bvlgari model al 38a l 3276?
Jul 29, 2011 | Bvlgari Aluminium White Dial Solid Black...
I have a Michael Kors watch with a white rubber wristband that has turned dirty and dark in less than a year. I am quite unhappy with how it looks, but very happy with the watch. What to do???
Thanks for contacting FixYa.
  1. The easiest thing to try is a regular pencil eraser. It's perfect for removing marks and smudges from rubber and works like a charm! Use white erasers as the pink ones may leave pink smudges.
  2. If a regular pencil eraser doesn't work, try a Mr. Clean Magic Eraser or similar product. Simply moisten the sponge and rub it over the stained area.
  3. If that doesn't do it, grab your safety goggles and move on to the next step.
  4. Mix four parts water with one part bleach in a cup or small bowl. You will need less than ¼ cup of the finished solution, so only mix a small amount.
  5. Wearing eye protection, moisten a white cloth with the mixture. Do not use a colored cloth. You will likely transfer color from the cloth to the watch band and make your problem worse.
  6. Carefully dab the bleach against the stain on the watch band. Don't over apply the bleach or leave it for more than a few seconds or you may damage the rubber.
  7. If needed, increase the strength of the solution by adding a bit more bleach. Do this in small increments to expose the rubber watchband to as little bleach as necessary.
  8. Blot and repeat as necessary if you see improvement.
  9. Once the stain is removed, rinse the band well with water to remove all the bleach residue.
  10. If the stain remains, mix the Rit Dye Remover with a small amount of water to make a paste.
  11. Spread the paste onto the stained area and allow it to set for a minute.
  12. Rinse with water and dry with a soft cloth.
  13. Repeat if necessary.
Additional Tips and Advice
  • Once you have the band clean, treat it with Armor-All wipes made for vinyl car interiors. This easy tactic will help protect the band from stains and smudging. Repeat every few weeks for maximum effect.
  • Be careful with acetone on rubber watch bands. It can start to break down the rubber and make the band feel "sticky." Once done, this can be difficult to reverse.
Best regards.
Jan 31, 2011 | Fossil CH2331 Wrist Watch
Hi, I have a swiss legend Commander watch with a rubber band. It is white and really needs cleaning. Also, it is coated with a rose-gold plated material on the bezel. Any ideas on how I can clean...
mcdevito75 here, For the Bezel (top part of the watch) the best bet is to use a jewelers polishing cloth available at any jewelery shop. For the white rubber strap, a few drops of water with a light hand, or dish washing soap on a wet paper towel or cloth should do very well.
Sep 20, 2010 | Watches
Missing piece to Luminox 3000 black rubber watch band`
Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
Mar 18, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
RECYCLE MY DIAMONDS
You should go to a diamond store and ask if they can do that for you .Your welcome.
Dec 30, 2007 | Lancaster Diamonds Luxuria - Pillola White...
Fossil Mens Atomic Big Tic Watch Box Set JR1210 Limited Edition Logo
Top Fossil Watches Experts
Jimmy Accardi
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
