Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Slow copying I HAVE A CANON IMAGECLASS MF4270. I LOAD THE PAPER TO COPY AND IT GOES REAL SLOW HOW CAN I SPEED IT UP THANK YOU PAUL Does anyone have an answer to this? We must have hit some button; all of a sudden the copier ADF is a VERY SLOW feed----HELP! it copies at 4.5 pages a minute. it is supposed to be 20 ppm. The screen and the printout says that the density is AUTO the image qualtity is TEXT
    Sergeant:
  • 320 Answers
Press the scan button with the colouror black option.press the scan and colour option button together.this will increase the speed of copying.
Posted on Mar 12, 2009
Changing copy speed of 70 ppm to 60 ppm in the Aficio MP 7001
Why? I don't understand why you need to slow the printer down. Now If you are using card stock or thicker paper and are trying to prevent damage to the media, make sure you have set the paper type and weight correctly when you load your trays. You also must make those changes in the software on your laptop/PC. If you don't, it will default to printer settings and never slow down.The device will slow down and open the gap between the hot roller & the pressure roller in the fuser to prevent creasing/damage to the document.
Feb 29, 2016 | Ricoh Aficio Mp7001 Copy Print Scan mp7001
My iR 3300 is very slow How can I make speed
dear
pl. do setting for image type to text or text/photo. the curling of paper mostly due to the fixing film unit. the pressure roller may softened. replace it or the path have toner clogged clean it with alcohol.
thanks.
Mar 04, 2015 | Canon Ir 3300 Black & White Copier
Ricoh 6123 b copy printer paper jamming in feeding section frequently.
store paper in dry conditions. check any rollers for being worn out
Jan 03, 2015 | Ricoh Office Equipment & Supplies
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
My canon imageclass mf4270 jams 90% of the time when i try to print. sometimes if i pull out the toner cart several times. it will print.
Hello sir; Check the paper path carefully is there have anything block over there, especial at both end. is the paper jam everytime at same place? cleaning up the roller with alcohol.
Aug 05, 2009 | Canon Office Equipment & Supplies
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Slow copying
normally, it's because you are copying in a high resolution. have a look at your user manual, lower the scan resolution and it should be a lot faster. Check that you're scanning in black and white -that can speed things up as well.
Feb 12, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon Printer MF 4270 has NO MAc software but Windows only.
try downloading here - http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=15753 - also choose the right operation system on top
Jun 26, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
66 people viewed this question
old marine
old marine
