Question about One For All URC-3021 Remote Control
One for all urs-3021 input code for a samsunge tv with vcr
Want to play xbox 360 but cant find the input channel. please help
  • Anonymous Jan 08, 2008
    Programming
  • Anonymous Mar 15, 2014
    Ii tried to fix it by pressing TV/video and it didn't work and there isn't any input button
YAW ARE USELESS PUNKS
Posted on Dec 21, 2009
Oh and I'm trying to play 360 also! if you find an answer write back on here.
Posted on Sep 30, 2008
**** this piece of **** website. I hope who ever made this goes and ******* kills themselves. Who honestly is going to randomly search websites to solve a code problem for urc-3021 remote. Whoever made the remote can ************ also. Have a great ******* day.
How to program aone for all remote control
Posted on Dec 13, 2007
What Channel should my Durabrand Old Model TV be on for playing Xbox 360 you see it Those not have a Red Video Input on the Tv to Play my Xbox 360
The good news is that the red cable is one of the audio channels. Your tv is mono and will work fine without the red cable. You need to hit the input button on your remote or your tv. You can also try hitting the channel down button. Once you get past channel 2 or 3, it should go to the inputs. I hope this helps.
Aug 01, 2016 | Video Game Consoles & Games
Hi mamita
0522 is the code for the xbox on your remote.
Mar 23, 2008 | One For All URC-3021 Remote Control
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
I have a 27 inch syphonic flat screen tv and I'm trying to get it on an input channel in order to play my Xbox 360
I dont have a 360 so cant be 100% sure this will be helpful. i have a PS3 and to get it to run on HD after using it on SCART, you need to plug both the HDMI and SCART leads in simultaneously and go into the system visual settings and change it to a HDMI port.
after this you need to jsut unplug the SCART.
im hoping its a similar issue but just swapping the PS3 menu's with the 360 one.
Oct 06, 2012 | Televison & Video
Can not change channel so i can play my xbox 360
i have a xbxox 360 unavirel remote but cant change my tv changel so i can play my xbox games how do i do this
Mar 19, 2010 | Televison & Video
No color on HD channel while playing xbox 360
this is sometimes due to an improper organization of the component jacks in the tv input. it doesnt sound like thats the case considering it was working before, but you might want to take a second look and make sure your colour coded component jacks are in their corresponding inputs.
Oct 05, 2009 | Bose Lifestyle 35 System
Why wont my xbox play in color
Sounds like you are using the Component cables but are not on the correct component channel. Keep searching through your input channels to find the right one. Some older TV's that intergrated component inputs merged them with the normal input channels. I had this same problem with a JVC TV.
Jan 09, 2009 | Microsoft Xbox 360 Console
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Xbox 360
http://serviceman.site88.net/index_files/GameConsoles.htm
Jul 05, 2008 | Microsoft Xbox 360 Console
One For All URC-3021 Remote Control Logo
201 people viewed this question
Top One For All Televison & Video Experts
Steve Allison
Steve Allison
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
