Question about Brother CS6000i Computerized Sewing Machine
Bernette Deco 500, will not pick up bobbin thread
I broke a needle, pulled out the bobbin case and now the machine will not pick up the bobbin thread
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
Where do i foun the scarf and needle bar on bernette deco 600
The scarf is on the needle itself. It is an indentation on the back of the needle above the needle eye where the thread can sit as the needle penetrates the fabric. As the needle penetrates the fabric, the thread sinks into the indentation thereby resisting fraying or pulling on the thread.
The needle attaches to the bottom of the needle bar. The needle bar is the mechanism that moves up and down to drive the needle through the fabric.
All About Needles
Bernette deco 600 diagram Google Search
Mar 03, 2016 | Bernina Bernette Deco 600
Is the bobbin supposed to move on the Bernette Deco 600?
Could you please let me know how you got this resolved. I just got this same machine and I am wondering the same thing...it just stopped picking up the bobbin and I have never really looked at it before that but the bobbin does not spin as well
Jul 21, 2014 | Bernina Bernette Deco 600
The bobbin will move only when the thread is being pulled. The problem with your machine is that the timing has missed aligned. It will need service. 99% of all sewing machine misalign due to continued use.
Deco machine will not pick up bottom threat
try changing the needle--make sure the needle is the correct
one for the fabric being sewed
try rethread the machine top & bobbin--use every thread guide
clean under the needle plate & in the bobbin area for lint
it's also possible that the timing needs to be checked at a sewing
machine shop
Oct 03, 2012 | Bernina Bernette Deco 600
My Bernette Deco 600 is not picking up the bobbin thread. I have cleaned the machine and retreaded many times. The sensor thinks there is no tread on the bobbin. What can I do to resolve this problem?
At the very worst you may need to retime the machine if you have already checked that the needle is in the correct way round and is a good one, I can attach timing instructions if you email me drivewithken@blueyonder.co.uk
Nov 02, 2009 | Bernina Bernette Deco 600
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
Bernette 600 deco
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Oct 07, 2008 | Bernina Bernette Deco 600
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Brother CS6000i Computerized Sewing Machine Logo
145 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
