Question about Dukane Office Equipment & Supplies
Ducane L3lCD projector lamp bulb replacement
How do you change the bulb?
Marrie
  • 563 Answers
SOURCE: VPL-fx51 Sony projector "Please replace the lamp"
Hi there
It is quite easy to reset the lamp timer nd remove the prompt.
Start up the Projector and hold down the right and left scroll buttons on your remote and then press Menu.
This will reset the timer.
Posted on Mar 26, 2008
SOURCE: Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Posted on Feb 09, 2009
Partstore
  • 34 Answers
SOURCE: xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Posted on Jul 30, 2009
    • 23 Answers
    SOURCE: Can't find replacement lamps for my Artograph Prism Projector
    or here: http://www.lumenarc.co.uk
    Posted on Apr 20, 2010
    SOURCE: sanyo plc-xp46 lcd projector
    In the on-screen menu...
    Press MENU, go to SETTINGS ICON, Move to Lamp Reset
    Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
    Posted on Aug 03, 2010
    How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
    hi
    this lamp has a small lamp pcb with a chip on it.
    have u change the complete module or have just changed the bulb.
    if you have just changed the bulb then u have to replace the small fuse on the chip.
    this should help to reset the lamp timer!
    Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
    We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
    Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
    Jan 14, 2011 | Hitachi CP-X450 LCD Projector
    How do I change the lamp? Lamp came with no directions. This is a HD72.
    Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
    copied from manual
    select the menu - default - clear lamp hour meter to reset lamp usage hours.
    Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
    May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
    Problems with Projector Panasonic PT-L501XU after change the lamp
    was this bought new or second hand?
    There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
    Look on page 40 and after that of your manual about ambient temperature bulb failure.
    By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
    Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
    How do I change the light bulb in the Sanyo pro traX multiverse projector
    unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
    Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
    Blinking red light
    replce lamp ballast board of your projector...
    Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
    Tech support for Sharp PG-B10S
    Reset The Lamp Timer.
    While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
    Sinista
    Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
    Problems changing lamp
    Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
    May 19, 2007 | Eiki LC XNB3 Multimedia Projector
    Top Dukane Office Equipment & Supplies Experts
    jasbo
    jasbo
    Jim Goldsmith
    Jim Goldsmith
    Denis J. Cabrera
    Level 1 Expert
    Are you a Dukane Office Equipment and Supply Expert? Answer questions, earn points and help others
