Question about HP LaserJet 4650 Color Printer
Printer will jam on mulitiple page print jobs gets a 13.1 error all rollers have been changed, jams just after the letter tray and only jams from legal tray 3 ???????
  • 34 Answers
OK you said you replaced the rollers. If you have not repalced the SEPERATION PAD, (located directly under your pick up roller....thats your problem. Easily done.
Posted on Mar 12, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Hp p3005n keeps getting paper jam error in tray 2 like every other page it prints and there is no paper jammed. I replaced the printer with a new one and get the same annoying error. So when you printing a...
I had the same problem, the transfer roller rubber was completely slick and would not pick up paper (it would also make a clicking sound).
Replaced it and the problem went away.
Jun 11, 2008 | HP LaserJet P3005n Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
HP LaserJet 4650 Color Printer Logo
115 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
