Question about NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
Wheel chair will not respone to any of the joy stick controller
Batteries have been replaced led's on the hand controller are lite up are they some kind of switch that has to be reset chair belong to my mother it has not been used since 2000.Can you help me?
I don't know if you got my answer. I just had this problem with my Guardian Aspire chair. They had to replace the electronic box on the armrest with the joystick. This is a BIG BUCK problem!
Posted on Mar 13, 2009
You have to move the two levers down by the footrest to the "drive" position.
Posted on Mar 20, 2009
My chair will not change speeds. Very slow, No flashing lights
That is possible. Check the power circuit from the battery and see if there is any loose connections or resistance in the circuit via the voltage drop method. Here are some links that may help:
Jazzy 1113 ATS Parts
Redirect Notice
Redirect Notice
Mar 03, 2015 | Pride Jazzy 1113 Power Chair
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
My power chair runs but wont move.
re-engage the motors look for two levers one on each motor and move them to locked position
Oct 21, 2012 | Golden Technologies Alante' Power Chair
Chair goes in opposite direction to joy stick control left and right only
batrans your motor connections are reversed. remove the seat and shroud over the batteries find the motor connectors that come from the joystick cable and switch them. This should fix your problem Hope you geterdone
Sep 13, 2010 | Jet 3 Ultra Power Chair
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 15, 2010 | Health & Beauty
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Jun 19, 2009 | Electric Jazzy 1115 Power Wheelchair
NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
511 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
