Question about HP D330 PC Desktop
How to instlall PCI device driver for integrated ethernet
I have problem with my Ethernet or integrated LAN card, it begun when I install PC camera and it was failure installation, and by this it make my connection was like unplug there is no connection even I Installed ethernet driver, but two led on LAN connection are running..when I checked on device manager there is yellow question mark for PCI, and when I run my computer there is found new hardware wizard with ask me to install PCI device driver, I tried to reinstall my OS but its no result, I also disabled PCI on BIOS, also it doesn't fix the problem..and it has tobe known that all aother device like sound, VGA and USB are running well...how to repair my PC? I so need the answer to fix the problem. Thanks alot for answering..
  • 135 Answers
Check the name of the card or model, download the driver to Internet just search for that? you'll needing to reinstall manually the driver of the PCI adapter to your computer.
Posted on Mar 12, 2009
I need to know whether the ethernet card for the Optiplex GX 240 is integrated in the motherboard or it is a card in itself. Thank you.
Pretty much every computer built within the last 5 years has built on network interface. However, to answer your question completely - look at the back of the computer where the network cable plugs in? Is it clustered around the video/sound, power, printer, usb, etc (integrated in); or is it located elsewhere (perhaps in the series of long narrow rectangular openings openings where the expansion cards go - separate).
Hope this helps.
Jun 02, 2011 | Dell Ethernet Card Network Adapter
I dont have an ethernet port on my pc only dsl dial up port, and my router only has ethernet ports, is there a lead or converter i can use to link my computer to my router?
You can buy a pci ethernet card/ network adapter pci . Installation would be opening your computer and insertig it to an available pci slot. If you have usb ports then you can buy a usb to lan device. Here are the picturesa1679da.jpg132f824.jpg
Oct 12, 2010 | Computers & Internet
Install lan Driver
You may download the LAN and all the other Drivers from the below link:
http://support.acer.com/drivers_download.aspx
Select the exact Model # of the Computer and download the Drivers.
Hope this helps.
Jul 09, 2010 | Acer Veriton 3600GT PC Desktop
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Mar 01, 2010 | HP Compaq d530 SFF PC Desktop
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
Question Mark in My Device Manager
dear,
pl install 1st chipset dirver from motherboard cd.2nd install vga/video driver,audio driver,ethernet/lan driver.
when require restart pl restart pc.
Feb 28, 2009 | Acer AOpen AW 724 Sound Card
ABIT is7-vs no ethernet
Have a closer look ... that appears to be in IS7-V2 board
http://www.abit.com.tw/page/uk/motherboard/motherboard_detail.php?pMODEL_NAME=IS7-V2&fMTYPE=Socket 478&pPRODINFO=Driver
If the link doesn't work right you may have to copy and paste the entire link into your browswer
Download the Realtek Lan driver you should be good to go
Robert
Please take a moment to rate this solution thank
Feb 03, 2009 | ASUS P4B533-VM Motherboard
One of two 3com pci gigabit ethernet cards is not working
If you have the driver disk that was distributed with the card , try reinstalling the card drivers first.
If the card is faulty, buy a new pci ethernet adapter and replace it, inserting the ethernet adapter into the pci slot.
After installing install drivers for the new card with the disk that will come with the card.
Ensure that you are logged in as administrator when you reinstall the drivers.
Nov 05, 2008 | SysKonnect Gigabit SK-9843 Network Adapter
HP D330 PC Desktop Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
