How do you drain water from my B&Q WAP-267EB Portable air conditioner unit
Its a B&Q WAP-267EB Portable air conditioner unit
5 Suggested Answers
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
dcp2
  • 63 Answers
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
  • 9 Answers
SOURCE: Air conditioner shuts down constantly, need to
Sorry but you are just going to have to keep emptying it. These types or air conditioners are also use as de-humidifiers and unless you can place it somewhere where you can connect a drain hose it is going to require many trips to dump the holding tank of the condensation.
Posted on Jul 12, 2010
How do I drain the water from unit before storing
Drain from valve at the bottom of the back of the unit. Look at page 6 of the instruction manual here: http://usermanualnmpeb08f2a.yolasite.com
Aug 25, 2012 | Maytag Portable Air Conditioner M6P09S2A
I am getting a code P1, what does it mean?
P1 Indicates that the water collection tank is full and needs to be drained. Turn the unit OFF & unplug it before attempting to drain it.
Hope this helped and thanks for choosing FixYa.
Sep 13, 2011 | Danby DPAC5070 Portable Air Conditioner
I have an Amcor 12000M portable air con unit. How do I top up the water tank?
There is no need to top of the water tank. When the unit is running it collects condensation and fills the tank with water. When the tank is FULL the Full indicator will illuminate and the unit will shut OFF. You will ten need to drain the water from the rear drain hole.
To further assist you, in case you have misplaced your Owners Manual. I have included a link to it that you can download & print for future reference.
http://dl.owneriq.net/a/ab0f1f5c-8efe-41da-a834-ba11df36ca35.pdf
I hope this information has helped you and thanks for choosing FixYa.
Aug 22, 2011 | Amcor AMC12000 Portable Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
Kenmore portable air conditioner Model 484.35338 serial no AP0000320252 made in spain code X5RKMFE709/01 quit running after 4hrs run. DRAIN WATER light is on. How is the water drained?
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan that can hold a least a quart of water. Or roll it to an area, where you can allow it to just drain. If you drain it in place into a pan, be sure to turn the unit OFF & unplug it, before draining the water.
If you have misplaced your Owner's Manual, you can get one online from Sears Parts Direct.
Hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Kenmore Heating & Cooling
I don't know if there is a place to drain the air conditioner unit.
jbuck, Since your unit is a multifunction unit (AC, Heat & Dehumidifier) you don't have to darin any water. It uses an evaporative system, that exhaust the water/moisture thru the exhaust hose to the outside. With that said, there may be a rare occasion, that the condensation pan under the unit, needs to be drained. In which case, you will find the drain hole, covered by a plastic screw off cap, on the left rear of the unit (as you face the rear of the unit), next to the cord keeper. A small plastic bowl or pan that will fit under the drain hole will suffice. As, there shouldn't be that much water to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | Haier CPN12XH9 Portable Air Conditioner
My portable a/c unit is leaking water & the indicator for "water full" is blinking red. How do I drain the water out of it
There should be a drain plug on the back toward the bottom of the unit, pull the plug and it should drain. Good Luck Tim
Aug 08, 2010 | Amcor Heating & Cooling
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Heating & Cooling Logo
912 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
