Hame a11w
Find a firmware update for this brilliant 3g Wireless adsl router ...
SOURCE: Router stops responding with red alert light turned on
Guys,
There is a new Firmware version 3.1 Beta release that is fixed lots of problems, though this version is unofficial and not yet released on 3Com website.
Download link: [url]http://aragostabbs.altervista.org/request.php?37[/url]
Enjoy!!!
Version & Build Date
3.1/ 2007/10/17
Modification
1. DSL code base update to 3.10.02.
2. ADSL phy driver version : A2pB022g.20H.
Bug Fixed
1. Java script error in Internet Setting page.
2. Dyndns and No-IP are Unworkable. Can not update server ip address.
3. Some gif link can not finish after added DDNS configuration.
4. RIP seems unworkable, Can not enable this function.
3.0/ 2007/9/24
Modification
Bug Fixed
1. ‘%’ issue in username and password.
2. DMZ cannot be removed.
3. Internet WAN add/modify UI error
4. IPSec unworkable. Can not to add and save IPSec Configuration.
5. Can not edit and cancel Port Mapping Configuration.
6. Change login timeout value, does not need check a password.
7. ALG Link unworkable(Removed).
8. Dyndns and No-IP are Unworkable. Can not update server ip address.
9. It does not arrive at the DDNS service which I set. Same issue in the TZO.
10. RIP seems unworkable, Can’t to enable this function.
11. If input ASCII value excluding 0-9 into year field, Current time will save and change to the “1970 0:00:00”.
12. “URL filter” Priority must higher than “PC Privileges”.
13. Content filter seems unworkable.
14. SIP Filter seems unworkable.
15. Some attack can’t be “Intrusion Detection” blocked. Ex: syn flood, ping flood, UDP flood.
16. At Internet Settings -> WAN page, if i enable the option "PPPoA" in Connection Parameters table, the IP Address field will display "undefir".
17. PPPoE does not work.
18. In WAP-PSK When the input value includes?’?, Encryption Function will crash.
19. A “Channel” item of Device Info information is not displayed normally.
20. Channel range is not correct.
21. Can not to disable “Radio” Function.
22. If DHCP lease table status is an “Expired”, a table will has some wrong.
2.9B_ A_SH_DATA_PUMP_20H/ 2007/9/13
Modification
Bug Fixed
1. Virtual server cannot be removed.
2. ROUTER ADSL PC Anywhere will not pass.
3. Java script error on E-mail alert function.
4. Java script error on Internet WAN setting function.
5. Java script error on WPA-Radius server function.
6. Add Jordan in country list.
2.9/ 2007/7/20
Bug Fixed
1. 3Com the 5th UI refine.
2. Support 3 more DDNS secrecies.
3. Support ‘-‘and ‘,’ for virtual server.
2.8b8/ 2007/6/8
Bug Fixed
1. debug firmware to dump memory information.
2.8b7/ 2007/5/15
Bug Fixed
1. failed to connect to device after unplug cable.
2.8b6/ 2007/6/5
Bug Fixed
1. DMZ entry Patch.
2.8b5/ 2007/5/15
Bug Fixed
2.8b4/ 2007/4/30
Bug Fixed
1. Support special characters for PPP username and password.
2. Support WPA-PSK with special characters.
2.8b1/ 2007/4/13
Bug Fixed
1. Fix UDP block port configuration lost problem.
2. support flexible schedule rule.
2.8b/ 2007/3/30
Bug Fixed
1. Fixed IPoA setting cause “out of memory” problem.
2. Add reboot log for debugging purpose.
3. Modify version name format.
2.8a/ 2006/12/22
Modification
Upgrade dsl driver.
2.8/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Modify schedule rule.
2.7d/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Please refer to SG GUI review pt 3.xls.
2. Disabled SIP ALG at default.
2.7c/ 2006/11/22
Bug Fixed
1. DHCP assign range problem.
2. DHCP fixed IP assign issue.
3. DHCP lease table not line up problem.
4. Turn one DNS proxy if NAT disabled.
5. Modify telnet session welcome message (BCM 96348 ADSL router to 3Com ADSL router).
2.7b/ 2006/10/27
Modification
1. Change system objects ID to 1.3.6.1.4.1.43.19.16/17.
Bug Fixed
1. LAN subnet mask shows up invalid error if set the correct value.
2. DHCP IP range assignment did not check weather is on the same subnet or not.
2.7a/ 2006/10/20
Bug Fixed
1. UI pop up warning message about DHCP IP range assignment.
2. LLC and VC/MUX display error.
3. Add DNS server to PPPoE and PPPoA.
4. Instability issue.
5. Login error while type correct password and press enter.
6. Upgrade countdown seconds is missing.
7. PC in different subnet unable to connect SNMP.
8. Lose System log settings after reboot.
9. Directly open file while saving configuration or log will cause open empty file.
2.7/ 2006/10/05
Modification
1. UI modification according 3com’s request.
Bug Fixed
2. Fixed Matis bugs. (Refer to mantis bug system)
2.6/ 2006/9/26
Modification
2. UI modification according 3com’s request.
Bug Fixed
3. Fixed Alert light on system hang problem.
2.5/ 2006/9/8
Modification
2.4a/ 2006/8/28
Modification
Bug Fixed
1. Set NAT default setting to enable.
2. Display URL block message.
3. Modified settings to apply right away. (only partial settings, some of settings still need reboot)
4. Wizard does not “pop up” after upgrade or reset to factory defaults
5. “OfficeConnect” banner in blue does not cover entire width of page.
6. Fixed channel in worldwide version.
Posted on Nov 14, 2007
HAAi
  • 77 Answers
SOURCE: ZyXel P660HW-T1 ... Problem bridging 2 wirless adsl routers
What do you mean by "wireless bridging"? Does it mean wirelessly connecting both routers? (ex. Zyxel is at location A and Micronet ais at Location B and you'll wirelessly connect them). If this is what you mean, then it might not be possible since those are two different brands and possibility is that they will not work with each other when they're wirelessly connected unless one or both routers have the capability to do so.
Posted on May 09, 2008
rahul26485
  • 611 Answers
SOURCE: SMC7904BRA2 adsl router won't update DDNS after IP change
because its give dhcp obtian auctomaticially so u give static ip and give the dns and download the frimware version latested one ok
Posted on Jun 10, 2008
yboyandrei
  • 828 Answers
SOURCE: connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Posted on Jun 16, 2009
nyilasrobert
  • 627 Answers
SOURCE: I have Compex WRL254G wireless ADSL router. I need Default passwo
username: admin
password: password
here is the manual too
Posted on Aug 05, 2009
Trendnet tew-658brm
The only firmware available is
Firmware Version: 1.03B12
Release Date: 05/2014
check the support site here for any more updates.
TRENDnet Support
May 02, 2014 | Trendnet TEW-658BRM 802.11n 300Mbps...
Unlock hame compatible with celcom 3g
1. Go at A11W UI by set in the URL of your browser the address 192.168.169.1 2. Go at the Login > Admin > Settings 3. At the end of page press the Export Button. Now, a file with name RT2880_Settings.dat will be saved in you hard disk. 4. Open the .dat file with notepad program. 5. Search for lines "CountryRegion" and below "CountryRegionBand". After symbol "=" delete the value (ATTENTION, lines to be remaining one below the other). Save file and close. 6. Repeat steps 1 & 2 above 7. Below button Export select button Select File. Press and select the .dat file tha you save before. 8. Press Button import. The .dat file will be load your new settings and A11W will restart. 9. You can use after any supported SIM card around world. Good lack!
Feb 05, 2013 | FocalPrice HAME A11W 3G 7.2M Integrated...
Which is the latest firmware update for the 2540U Router? http://ftp.dlink.ru/pub/ADSL/DSL-2540U/Firmware/ is the only site I can find with updates on it but I'm not sure which to choose.
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Apr 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a wireless 300n 3g router witch i cant get working... i can access the router trough wireless and wired connections but wont let me access the internet.. i have an eircom 3g stick plugged into it...
Hi,Just go to the Intellinet website and download the most recent Firmware with Modem update. I had the same problem with one of the latest 3G modems and the latest firmware had that sorted out.
Dec 27, 2010 | Intellinet Active Networking (520638)...
Using abelkin F5D7633-4 for 2 years no problems untill now the adsl light is nolonger lighting up
u could try a line test with ur ISP, if that is fine, u have to go for a firmware update of the modem router. download the correct firmware depending on the correct version.
Jan 13, 2010 | Belkin (F5D7633UK4A) Wireless Router
Very low signal (wireless maxg adsl gateway usr9108)
Have you tried changing the channel? This might help icrease your signal aslo avoid putting it near wall and if possible put somewhere higher (5-10 ft above the ground)
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Ntech ADSL AWR54A router may be an wireless
I believe it can't be done on this model of router. Some wireless routers have this capability depending on the firmware version. But mostly, ADSL routers doesn't have this capability. It can be used as an extension but you need to extend a long ethernet cable from the first router going to your ADSL router. It can't be done wirelessly
Apr 26, 2009 | Computers & Internet
Repeater function
you make a device into ap mode you can get it
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
Computers & Internet Logo
267 people viewed this question
David Payne
David Payne
