Question about Westinghouse SK-32H240S Television
Main board is bad what cause this to happen? only had it for less than 2yrs. tv-lcd/dlp major model sk=32h240s serial 5060j72100290 how much does this cost.......
  • Anonymous Apr 17, 2009
    same problem with the damn purple light
  • 718 Answers
Is the LED light purple ?
Nearly all TVs are made in 3rd world countries using the cheapest labor possible with the cheapest parts, minimal quality control, non robust design, and no tests for long term durability.
If you have definitely determined that the main board is bad, someone knowledgeable in electronics can replace it. You can get one from the places like Ebay on the 'net.
I found a "pulled" one for about $123 at http://www.shopjimmy.com/tvrepairshops.cfm but you may do better if you look.
I have only read bad things about this model. Here are some of the things I have come across. Try this first. With the TV on, unplug it, wait a few seconds an plug it back in. You may also turn off the energy saving mode.
Posted on Mar 12, 2009
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
Westinghouse SK-32H240S no backlight
The voltage source to back light inverteres are from the main power supply regulator board. Check it.
Jul 20, 2012 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to westytech@westinghousedigital.com. Please rate my answer if it was helpful, have a great one.
Mar 28, 2011 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
This model has what are called a LIPS board in it which is a board that has both the power supply and the inverter on the same board. What you need to do is replace this part and your TV will be as good as new. To obtain this board simply email parts@wde.com and they will let you know price and availability of this board. Please make sure to include model#, serial#, and TW#, all located on the back of the unit.
Jan 19, 2010 | Westinghouse SK-32H240S Television
We need a replacement bulb for our westinghouse LCD tv sk-32h240s, but don't know exactly what part to order
Hello, you need what is called a LIPS board which is power/inverter board, in order to get price and availability please email parts@wde.com, make sure to include model#, serial#, and TW#, all located on the back of the unit.
Dec 24, 2009 | Westinghouse SK-32H240S Television
SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Jul 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Mar 28, 2009 | Westinghouse SK-32H240S Television
BROKEN SCREEN
You can find one on the 'net but it will not be cost effective.
You will be better off selling your set for parts and buying a new set. The LCD is the major cost of a set and when it goes, it's not worth replacing. Warrantees generally do not cover breakage either.
Feb 04, 2009 | Westinghouse SK-32H240S Television
Televison & Video Logo
989 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
