Question about Cooktops
Defy dhd338 glasstop hob left front plate switches on continuosly
2 Suggested Answers
  • 3 Answers
SOURCE: What thickness cable should be used?
15 amp cable
Posted on Jul 20, 2009
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
26 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
