Question about Bionaire Heating & Cooling
Pyrox gas heater narrawai mkiv making purring noise not the fan
Making vibrating noise at the canles not the fan
5 Suggested Answers
  • 4 Answers
SOURCE: MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Posted on Dec 31, 2009
roniecon
  • 6927 Answers
SOURCE: Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Posted on Jun 15, 2010
Testimonial: "Thanks for your help. Have located the problem now thanks. It's the gas line. Strong smell of gas outside. Grateful for assistance. "
  • 3253 Answers
SOURCE: i have a problem with a pyrox gas heater that
check too see if pilot is clean and check air ports to pilot could be blocked
Posted on Aug 08, 2010
  • 403 Answers
SOURCE: The Unit is maybe 2-3
replace the t-stat
Posted on May 25, 2011
I can't get to the fan on my pyrox gas space heater model HEA24M
Take out the wood columns there should be scews on both sides to remove the front panel.
Aug 02, 2016 | Heating & Cooling
My refrigerator is making a loud purring sound. What can I do to make it stop?
It is so common that the fridge can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that fridge is vibrating when it is running then the compressor motor fittings has to be inspected. check the mounting of the motor , check for SYMPATHETIC vibrations to the plastic body /rear covers that can produce these loud purrings. If so tighen the clips or use some rubber damper sticker- one side sticker with padding- so as to reduce the vibration and noise.
Jul 13, 2011 | KitchenAid KSSC42FMS Side by Side...
Fan makes a loud vibration noise
I suggest it is one of 2 problems.
1' The bearings have gone on the blower fan wheel.
If you remove the fan section from the heater, these can be replaced at a local bearings store.
2\ The fan has become unbalanced and is knocking on the surround.
Remove the fan assembly an clean with a damp cloth and compressed air if you have it available. Dust build up can cause this problem.
Best of luck, but it should be a fairly easy fix!
Cheers,
John
Dec 23, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Jun 15, 2010 | Heating & Cooling
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Inside back of freezer making a loud noise like a horrable vibrating noise. whirlpool side by side ED22TQXGW00 sounds like something is vibebrating real bad it's a whirlpool sj2446090 model ED22TQXGW00...
Hello the fault is most likely to be the defrost system building up frost around the fan and causing the bad sound to prove this just turn off freezer for about 10 hours to defrost and restart if noise has gone away then your defrost system is faulty
Apr 07, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
Require fan for pyrox lpg radiant gas heater unit approx 4 years old
THANK YOU FOR THE REPLY
NOT MUCH OF A PROBLEM WILL CONTACT YOU IF WE NEED TO FOLLOW UP.
Aug 19, 2008 | Heating & Cooling
Heating & Cooling Logo
169 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
richie46
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
