Question about Proform Crosswalk 500 Treadmill
Belt speed fluctuation
And after I turned the two hex screws for adjusting the belt tension a quarter of a turn tighter, I only here a bump and no movement from the belt....I went a quarter turn looser and even a half and still nothing?????? just bought the thing and having doubts!
    Problem Solver:
  • 12 Answers
I assuming these hex screws are near the rear of the unit. But they should not affect operation unless really out of whack, but they should be adjusted with the belt moving. Try manually moving the belt first.
If it moves and If it is a newer machine more than likely the motor sensor is telling the control board that the motor is not working and it is shutting down as a safety measure.
If it doesn't move - somethings jammed
Posted on Mar 13, 2009
Chain saw won't keep running
There are 2 adjusting screws, one is idle speed and the other is mixture. Adjust the idle screw until it keeps running. That may be all you need. But to check that the mixture is right turn the mixture screw, quarter turn at a time, keep count! until it flutters or speeds up. If it speeds up stop and adjust the idle back a quarter turn at a time until it runs without the blade turning.
Oct 25, 2016 | Garden
Need to know how to adjust tensions.
Make and model not stated. Most machines have a dial for upper thread tension. Higher the number, the tighter the tension.
Bobbin tensions can also be adjusted, but it is not recommend that sewing novices attempt to adjust bobbin tension. (Bobbin tensions are very sensitive and a slight quarter-turn will usually make a big impact. Plus, one should know how to return it to its original position if/when things go awry.)
Mar 31, 2015 | Sewing Machines
How do I adjust the belt on my TX40sportcraft threadmill
Set the speed on the treadmill at 2 MPH, If the
walking belt has shifted to the left, use the hex
key to turn the left idler roller screw located on rear
of walking deck clockwise 1/4 of a turn; if the walking
belt has shifted to the right, turn the left idler roller
screw clockwise 1/4 of a turn. Be careful not to
overtighten the walking belt. Always wait to see if the
belt moves as your turning the screws. Take your time
in adjusting belt.
Mar 02, 2015 | Exercise & Fitness
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Mar 03, 2014 | Proform Crosswalk 395 Treadmill
Put new drive belt in but will not hold tension
there is two screws, that holds motor that you can adjust to get that belt tighter, basically if its not tight just make it tighter.
Feb 26, 2011 | Maytag Washing Machines
No power streeing at slow speeds 2002
Check the tension of the belt. If you have one belt that runs everything then replace the belt tensioner. If the pump has it's own belt then you can adjust that belt tighter
Nov 21, 2010 | 2002 Subaru Outback
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
I adjusted the belt so it would be more centered by following the instrucitons in the manual- turning left side hex screw 1/4 turn at a time until more centered. once it was more centered the belt started...
Under your motor hood you have a drive belt that can also slip. Depending on make you may after loosening the motor bolts and have an adjusting bolts.
Feb 25, 2010 | Proform Exercise & Fitness
I can not tighten the alternator belt on my hyundai 2001 300 xg
If it doesn't have an automatic belt tensioner there will be an adjustment screw on either the alternator or power steering pump (possibly both if there are two belts). Loosen the two mounting bolts securing the accessory (ie: alt or p/s pump) and tighten the screw. Once adequate tension is on the belt tighten the mounting bolts.
Sometimes the adjustment is on a seperate pulley and not one of the accessories. If this is the case, loosen the center bolt on the pulley and tighten the adjustment screw. Once tight, tighten the center bolt.
If you have an automatic tensioner there are no adjustments to make the belt tighter.
May 09, 2009 | 2001 Hyundai XG300
Title: Treadmill Belt Problem
determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Jan 06, 2009 | Nordic Track NordicTrack Treadmill, A2550
Proform Crosswalk 500 Treadmill Logo
248 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
