Question about Delta T17238-SS Stainless Steel Lahara Double Handle Pressure Balanced Show
Thats a no brainer... but there is a temperature valve on the faucet itself. I would like to now how to remove this lever from the faucet and set the temp.
    Problem Solver:
  • 9 Answers
Then remove the handle cover and the handle there should be a screw to adjust it with
Posted on Aug 01, 2009
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    I have a one handle shower/tub faucet, and when you run straight hot water (to preheat for example) the water shuts itself off. Lever is still in the lifted/on position however. Cold is fine, even warm...
    If this is a newer valve what is probably happening is the valve is a scald guard valve and is shuting itself off when it senses no pressure on the cold side. I don't have a lot of experience with am. std. valves but I'm sure you can get instruction on line to set heat setting on valve higher. Thank you.
    Jan 20, 2011 | American Standard One Handle Tub & Shower...
    Install trim and adjust the thermostat on a Grohe shower faucet
    Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
    Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
    Leaky single lever bath tub faucet
    Faucet is leaking due to seats bad.
    1- Turn water off first and remove handle and remove collar that holds stem and remove it..
    2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
    3- Remove them and the springs and replace them this will take care of the leaking problem.
    May 21, 2010 | Delta & Single Handle Shower Faucet
    Only warm water from the tub/shower
    You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
    Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
    May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
    Remove the cartride for the danze d454612
    First you have to remove the main lever/handle. This is done by loostening the allen head setscrew at the pivot point front base of thge handle. Underneath you'll see a collar or nut that is easily removed with a pair of Channel Lock pliers (adjustable) then after marking the front of the valve with a permanent marker(just make a dot) so it is assembled the same way, pry out the valve and repair or replace it, Thank you, Dana.
    Jan 23, 2010 | Danze D403412 Melrose Single Handle...
    How do I remove the single lever? I removed the screw, but the lever is still attached. I think we have a diverter problem because the sprayer is working, but not the faucet. Does the actual lever...
    What often happens with this type of faucet is the shaft becomes corroded inside the lever. If you place a cloth around the base of the lever and pry upward with two equal size large screwdrivers the lever "should" pop off. I've had to replace several of these type unit for this very reason. Thanks, Dana
    Jan 06, 2010 | Rohl A3608LMPN Single Lever Country...
    WATER IS WARM NOT HOT AT SHOWER EVERY WHERE ELSE WATER IS HOT
    If this is a single lever faucet, they have a plastic "geared "peice that is adjustable so the water can be very hot at a sink but will allow the
    shower / tub to be set at a lower mixing temperature to prevent scalading someone. to get to it remove the center cap and remove the screw from the center and remove the outer knob that sets the hot cold mix, the "gear" peice is there, set it left or right by one tooth at a time and check it till you get the disired temperature, you can remove it totaly but then it will get as hot as the water heater puts out.
    Nov 08, 2009 | Delta RP17453SS Standard Diverter Tub...
    My mixet bathtub faucet only produces hot water
    single lever facets do this all the time
    flip the facet leverover
    ie remove lever and spin the center gut 180 degrees re install the lever and wala you have hot and cold water
    if not check your supplu lines dont have a kink in them or they are not pluged
    remove hot supply line and open feed valve over a bucket no water ?
    turn on the other shut off valve
    remove cold line over bucket open valve you have water then you have a bad faucet
    return it then install a glacier bay faucet they are cheep and they work well
    Jul 25, 2009 | Home
    Delta Kitchen Single Faucet 470 suddenly would not give water
    Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
    Jun 15, 2009 | Delta Faucet Delta 470-BL-DST Signature...
    Delta T17238-SS Stainless Steel Lahara Double Handle Pressure Balanced Show Logo
    95 people viewed this question
    Top Delta Home Experts
    Mike
    Donni Steen
    john h
    Are you a Delta Home Expert? Answer questions, earn points and help others
