Question about Microwave Ovens
Defrost in kupper microwave - Microwave Ovens
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
How do i defrost in a prestige 3de microwave
If you don't know how to program defrost or if the unit does not have variable power settings, you can put a cup of water in next to the package you want to defrost and run the microwave for 30 seconds at a time. I don't advise defrosting meat in a microwave but I guess sometimes you have to.
Jan 30, 2015 | In Microwave Ovens
I need to know how to use the defrost on the microwave
You read the weight of the food on package (in lbs)
Put the food on a microwave safe plate /container.
Close the door.
Press the Defrost by weight button
Enter the weight of the food. The time will be set automatically.
If you have a defrost by time, just decide on the time duration and enter it
Nov 28, 2013 | Microwave Ovens
How do I defrost a turkey in the microwave
If you're feeling brave-and if your oven is cavernous enough-it's also possible to defrost your turkey in the microwave. You need to zap the bird on a low-to-medium energy setting for at least 6 minutes per pound (two hours for a 20-pound bird), being sure to rotate it occasionally from top to bottom and end to end. Because it's possible that the microwaveicon1.png will start cooking certain portions of the turkey, it's necessary to start cooking the bird in a traditional oven immediately after defrosting.
Read more: How to Defrost a Turkey ' eHow.com http://www.ehow.com/how_6592_defrost-turkey.html#ixzz2G5Xd3BUs
Dec 25, 2012 | Microwave Ovens
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Sharp microwave r220hw
Seeing as it's a Microwave, not a freezer, I would think all you would have to do is turn it on .. it will defrost itself in no time!
Nov 16, 2008 | Sharp R-220HW Microwave Oven
GE Microwave TimeCook defaults to Defrost Auto
It sounds like your keypad (membrane switch) is failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. You can use it to test for a bad keypad.
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link her eon Fixya http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
