Question about HP 270 Copier
Broken carriage belt
The carriage belt broke on my copier and I cant seem to find one. Could you tell me if HP has replacement belts?
  • 4 Answers
Yea they do http://www.everprint.com/online/simdetail.asp?partno=C4557-40049 I think that would fit.
Posted on Aug 03, 2007
SOURCE:
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
Hp psc 2175 all in one carriage belt is broken and cannot find replacement
Carriage belt is not a user replaceable part. Hence you cannot replace it by yourself. This unit should be repaired by an HP authorized technician. Please contact the nearest service center to repair it. But I think the repair cost is close to the price of a new printer.
:) Dr Tony
May 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
The narrow rubber drive belt in my HP PSC 2210 has broken.
I have an HP Photosmart 7550 and the carriage drive belt stripped then broke. Efforts to find a replacement belt were in vain. So, with nothing to lose, I glued the ends back together (just to hold them in place) and sewed a thin piece of nylon tape, maybe 1.5" long, over the break. Just folded it over the belt and made 3 lengthwise passes with a normal sewing machine. Installed the belt with the splice in a spot where it will never see the toothed drive wheel. And it works perfectly!
Mar 07, 2010 | HP PSC 2210 All-In-One InkJet Printer
The print cartridge will not move
There is a "belt" (with pulleys at each end, and the carrridge in the middle) that pulls the carriage from edge-to-edge.
If that belt is broken, or the clamp that connects the belt to the carriage is broken, the carriage will not move.
It's cheaper to replace the printer, and responsibly recycle the old printer, than it would be to try to repair the printer.
Jan 05, 2010 | HP DeskJet 5650 InkJet Printer
The belt that moves the printer carriage is broken.
The best way to find a replacement part is to find a non-working printer of the same make and model. HP's are very common and by searching the major ebay or craiglist website you will likely find one. Otherwise, post on one of the possible sites that you are looking for a non-working printer.
Sep 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
DesignJet 450C (E-size)
I replaced that belt about a year ago...it took a long time but seemed to go fine. I have a manual "carriage belt installation instructions" its 12 pages long. check out HP website and if you cant find it online, I could scan it for you.
Mike
[email protected]
Mar 29, 2009 | HP DesignJet 450c InkJet Printer
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Print head carriage drive belt failure.[hp deskjet 710c]
there is a rubber belt that moves the head from left to right if its broken it needs to be replaced or if its just got loose open the sides of the printer and then refit the belt there is a small section given in the back of the carriage where the belt fits.once u will open u will get the section easily.
Nov 20, 2008 | HP DeskJet 710c InkJet Printer
Broken belt on HP 882c
Sep 14, 2008 | Office Equipment & Supplies
HP PSC 2175 Cartridge Belt
Ok, I will try to explain how I fixed mine as best as I can. I took it all apart and realizing that the belt moved the cartridge carriage I thought 'hmmmm' and took the belt, cleaned it and the cartridge carriage and in the channel on the carriage where the belt sits (sort of W shaped) I put some 'Gorilla glue' and put the broken ends down into the glue. I let it set up for about 6 hours and my printer has been back up and running ever since. That fixed the broken cartridge carriage belt for me. Now if the other belt breaks then I guess I will have to break down and buy another printer but after 6 years of service I can't complain. And yes I have been refilling now for over 4 years. I hope this helps.
Kazdagi
Jun 22, 2008 | HP PSC 2175 All-In-One InkJet Printer
147 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
