Question about Sony VAIO VGN-T250P/L Notebook
My Third VGN-T250P just died. always the same, stops cold.
Always the same, one second working fine the next totally dead. No lights at all. The last two were working on battery the first one was plugged in. DC supply is fine (I have several) and I've checked that the power in connector is ok and that power is getting through the black and red wires across the back to the board under the keyboard near the QWA and S keys. I've had them apart several times for HDD and fan replacement.
HELP
  • 3 more comments
  • atwood772 Mar 12, 2009
    It has been 2 years since the first one died (and is still dead). I'm sure it had cooled off by now
    As in original post. It is totally dead. No fan, no lights (including the battery charging light)
    sounds like no one is actually reading the post. All three are totally dead. No boot, no post code, no fan, no lights no USB power, nothing at all. One would suspect the main power supply.
    So the solution is to take it to someone to fix it? Since 3 of 3 have died in exactly the same way there would seem to be a design problem. What I want to know is what component has died. There is no obviously burned component, I've looked quite carefully and I do this stuff for a living.
    nope
    Top Expert:
  • Sony Master
  • 78,267 Answers
Sounds like u will need to replace the power supply which is part of the motherboard.
Posted on Mar 12, 2009
    Sergeant:
  • 320 Answers
There is a small component in your notebook pc.the number of the component is IC367 .THIS ic controls all the power system in your note books.as you sdaid the notebook is completely dead-- no fan ---no lights.then its quite necessary to check out on the main board and replace this ic from it.the cost of this ic will be near to $3 per ic for each note book which is dead.get it repaired at local repair center .it you find hard to operate multimeters and soldering irons.also get the circuit board checked at the repair center so that they can check out as to why this IC blowned up in all your note books.
  • Sony Master
  • 13,433 Answers
Sounds like something on the motherboard failed. Have you contacted sony for repairs?
  • Ekse Mar 12, 2009
    motheboard or the power board, they are generally on the same board, has failed.
    Well this kind of problem, generally replace the board or get the board repaired.
    Sergeant:
  • 254 Answers
Its the problem of the components getting overheated in the main board.and at last they just blows up and the unit becomes dead.to resolve the issue the just get the internal board checked and replace the faulty.it will not be too costly to get it repaired as the components are not too costly.
    Brigadier General:
  • 8,619 Answers
Hi!
Have you checked the power supply board and heat sink? Is the fan working?
  • Rylee Smith
    Rylee Smith Mar 12, 2009
    Yes its the power supply thats at fault. This may have happened due to excess current through the power adapter, change the power supply of your laptop.
  • Sony Master
  • 19,396 Answers
Ensure that the laptop is not overheating and shutting down, in that case replace the cooling system.
  • Ginko
    Ginko Mar 12, 2009
    Check the temperature of the system, Download SpeedFan and check if the temperature is getting critical.
    In that case check that the fan is starting, if not , replace the fan.
    Also ensure that is not a system problem, start the laptop from a boot cd and leave it on, if it does not shut off it is either the system or a device like the video card, that can fail only in determined runtime conditions.
Computer will not start
It seems that your OS has registry problem, there are only two ways to fix it:-
1) Re-install your Windows with Re-partition your drives (In that case you have to take backup of your all data.)
2) Start PC in Safe mode, then download a reliable program like i always use Reginout to fix my OS registry properly.
Thanks
Dec 29, 2013 | Sony VAIO VGN-T250P/L Notebook
My 95 3L Lebaron Dies when the car is stopped. It starts then dies immediately, after many cranks with lots a gas it will run. Only happens when cold.
I'd use a gage and check proper fuel pressure, key on engine off. My info says 48 psi.
How long since over-all tune up?
Apr 16, 2017 | 1995 Chrysler LeBaron
My royter delink 602 stopped working
Check all lights are working.
If totally dead, check wires connected OK.
Reset with pen tip or opened out paperclip while holding power in.
All lights will stay on for 10 seconds then it should reset.
If totally dead, still, check fuses
Jan 03, 2011 | D-Link Computers & Internet
Added memory to laptop, nothing on screen now
remove the memorys and check the memory slots for any damaged pins .test the memory one by one on 2 slots(power off place one memory on slot1 and power on then do that procedure on slot2 ) if the laptop boot, one memory or one slots have problem and you can work with another one ,if you didnt see the boot screen at all try to reset the Bios .
if still dont work have to repair or replace the mainboard.
Aug 12, 2009 | Sony VAIO VGN-T250P/L Notebook
T250p will only boot up to a small blue screen and halt? How can I go into safe mode?
To get into safe mode When you first turn on your laptop keep pressing the F8 key and it will bring you to a system menu. From there choose safe mode, should be the top option.
Jun 30, 2009 | Sony VAIO VGN-T250P/L Notebook
1991 Mazda truck starts, then dies unless
Not a solution but i am going through the exact same nightmare and same symptoms with my 1991 mazda b2200. I've apwnt over two grand to have my rebuilt TWICE and my alternator replaced and still does the same thing just starts only to die 2 seconds or so later unless i let it warm up to its max but will still die when taking turns and stopping at lights.
Mar 23, 2009 | 1991 Mazda B-Series
Is it my battery?
well this is what you should try ,,jump the car get it running
then when its warmed up take the positive lead of the battery
if the car stops the alternator is gone (thats what charges the battery) if the car runs its fine
and if u have put another new battery in it and the alternator is fine look for any broken wires earths or positives that could be making it drain so quick
and make sure your battery levels are full
hope this helps
Jul 02, 2008 | 2001 Mercury Cougar
Will not run after a few seconds
sounds like a main pc board and or capacitor problem
Sep 17, 2007 | Kenmore 54351 Dehumidifier
Sony VAIO VGN-T250P/L Notebook Logo
128 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
