Question about Dryers
Flashing timer light when an Onsen ASW-H18B4/ETX unit is turned on, and vents open but no heating or cooling is blown out.
  • 1894 Answers
SOURCE: Daikin heat pump, turn it
just try leaving the unit plugged off from the main power for few hours.
then try switching ON.
Posted on Jun 29, 2008
  • 668 Answers
SOURCE: Timer flashes, then lamp light comes on. Unit will
DM module is not booting up because there are some capacitors in its power supply that are defective in your tv .There are four capacitors that go bad inside your tv in DM module . You need to replace those 4 capacitors . It will cost you around $40 . If you're not a tech, and you'll most likely need to call technician to repair your tv . Hope this helps .
Posted on Jan 23, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: LG LMVM 1935SB doesn't heat.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See this file for more help on door switches.
The service manual for your oven is here, but does not contain part numbers.
If you only need a switch, you can order a universal type here for $5 postpaid.
For other part help, contact
Encompass here or call call them toll-free at 866-779-5835.
Let us know if we can help you further.
Posted on Feb 10, 2010
Testimonial: "Excellent diagnosis. That did the trick. THANKS SO MUCH FOR YOUR HELP!!!!!!!!!!!!!!!!!"
  • 119 Answers
SOURCE: Daikin FTY45EV1A split system wont turn on, has
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Posted on Jun 14, 2011
SOURCE: the timer light keeps flashing and unit does not
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Posted on Jul 01, 2011
HOW I CONNECte remote control to fujita air ASW-H18B4/HS
If it the correct remote control for the unit, point remote to unit and press power button this is normally followed by a beep to confirm unit has received command,
if this does not work please check battery's to ensure they are still fit for purpose
Dec 24, 2015 | Heating & Cooling
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Model A12AWU-UF7
That is an alert code. Most heaters require forced air venting, and some use a vacuum switch to test for that airflow before igniting gas flame.
May 07, 2014 | Heating & Cooling
Onsen split air conditioner showing code E5 what is wrong?
I have an Onsen split system air conditioner but i cant turn it on today for some reason. The timer light is flashing 4 times.Its look like error 4.Any suggestion?
Oct 10, 2011 | Heating & Cooling
The unit will turn on but there is no heat. i have cleaned the unit and checked for blockage. the unit will run and won't shut its self off.
No heat is usually caused be either by a bad heating element or a plugged vent. Many vents also have a flap inside of them that close when the dryer needs to heat up and opens when it needs to cool off.
Also when a dryer doesn't shut off, it is usually due to a fault timer.
If you have a bad control board which is fairly common, you will have more than one component that is not operating correctly.
Jun 14, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
Lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
May 18, 2008 | LG DLE7177 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
