Question about Maytag Dryers
Dryer won't turn the drum so the clothes are not dry at all.
  • feedon1012 Mar 12, 2009
    The old belt came loose, did not see how did it hook to.
    I have tried to install new belt (exactly same brand &model) but no succcessful. It was too loose.
    Please show me how to install the belt right fit.
    Thanks,
    Don
  • 3 Answers
Sounds like the belt is broken that connect the drum to the motor.. These are usually cheap to order online but more difficult to install. I would take the cover off just to see if the belt is still connected before calling anyone.
Posted on Mar 12, 2009
Dryer won't spin
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Dec 05, 2012 | Whirlpool Dryers
Dryer won't dry clothes
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
Nov 09, 2012 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Dryer drum won't turn with clothes in it
nothing hasent fell out of the pockets has it? or it might be that there is to much cloths in the dryer
Apr 21, 2012 | Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer not drying clothing.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | GE Profile Harmony DPGT750EC Electric...
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 07, 2009 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dryers Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
